SOURCE: Vaio Recovery Center not working
If the hard drive is full, clear some space.(run disk clean up)
locate and empty the TEMP folder.
Then
Please rate this a fixya
SOURCE: Win Xp Drivers for sony vaio vgn-fw230j
Go to download the drivers that you require from the Sony WEB site, to their support/download page. Make sure you input your model laptop and select the Windows OS that matches your installed operating system.
Use this link :-
http://esupport.sony.com/perl/select-system.pl?DIRECTOR=DRIVER&SR=nav:service_support:electronics:drivers_software:esup&ref=http%3A//www.sony.com/index.php
SOURCE: I need a recovery disk for Sony Vaio VGN-NR11s/s
here is a disc made by these guys http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
both 32bit and 64 bit
in your case the VGN-NR11 is 32 bit
SOURCE: Corrupt Recovery DVDs for my three year old Sony VAIO VGN-N130G
Check this Link to get the Recovery Disk for your Computer:
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=partSearch&searchText=Y8315692A
Good Luck!!!!!!!!!!!!!
Testimonial: "Thanks pal."
SOURCE: Sony Vaio VGN-NR498E recovery disk
Hello
Well, the recovery disks won't allow you to go to your present system. The recovery disks are designed to put everything back the way it was when you bought the computer, minus all your applications and data. If it's your data that you need then a reputable repair service like mine can slave your hard drive to another system and recover all your data (not applications), provided the hard drive has not electronically or mechanically malfunctioned. Again, a reputable repair person can tell you the status of the hard drive.
Thanks
