20 Most Recent Sony VAIO VGN-CS215J/W Notebook Questions & Answers
To use Vob files with movie maker, they need to be converted first. This can take a little while, but there is no other way, as windows doesn support dvd playback by default, and whilst codecs will give you playback, movie maker will not accept them, even with the codecs. To convert your vob files to "avi" (the format needed for movie maker) yoou will need converting software. Most of this is very expensive, but thankfully, one of the best is actually free! It's name is "super" and it can be found at the following web address http://www.erightsoft.com/S6Kg1.html
By the way, the download link is at the bottom of the page.
Wish you the best of luck,
06castwo
Sony VAIO... | Answered on Sep 26, 2019
Just install VLC player. That is a free media player, light and supports most formats, including the VOB files.
Jules
Sony VAIO... | Answered on Aug 21, 2019
Welcome to Fixya. To be able to fix the issue you need to press FN + Numlock key of your keyboard. The numlock key is on that's why number appears instead of letters. Numlock key is next to F12 button.
Thanks for using Fixya.
Sony VAIO... | Answered on Nov 30, 2018
it may be that you have a broken display signal cable in the unit. these are pretty cheap to replace but do require getting a trained technician like myself to replace it for you, as there is a significant amount of work involved in actually swapping it out.
good luck, tim
Sony VAIO... | Answered on Nov 03, 2015
you need backup all your data on laptop firstly. The tool will help you!
Windows Boot Genius
Sony VAIO... | Answered on Feb 19, 2014
sadly as with most laptops it is normally cheaper to turn around and buy a whole new machine then try to replace a motherboard, so unless you desperately need that exact machine i suggest getting a new one
remember if it's helpful rate it, cheer's the tech team
Sony VAIO... | Answered on Oct 20, 2013
How to replace the keyboard on vgn-cs24gh
Sony VAIO... | Answered on Aug 07, 2013
if your pc currently had vista then a windows 7 recovery will not help. if you have a windows 7 key or vista you can format and start fresh providing the hard drive isn't what's corrupt or damaged.
Sony VAIO... | Answered on Jul 30, 2013
Remove main battery and power up, next! sub out the ram one at a time and test, remove the second piece and put the first one back for a valid test.
Sony VAIO... | Answered on Mar 23, 2012
Hi.
According to the information online, the issue might be due to the VAIO Launcher Application.
The VAIO Launcher Application is responsible for the functionality of the AV Mode keys.
Hence, it would be better to re-install the VAIO Launcher Application.
It is also recommended to install the Sony Shared Library before installing the VAIO Launcher Application.
I have mentioned all the links from which you can download the Sony Shared Library and the VAIO Launcher Application:
Sony Shared Library:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS215JW&upd_id=4236&os_id=34
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS215JW&upd_id=4403&os_id=34
Please click on the above links to download the Sony Shared Library and the VAIO Launcher Application.
Hope this helps.
Please feel free to contact for further information and assistance.
Sony VAIO... | Answered on Feb 08, 2012
i think you need to reformat and reinstall the OS on the machine to fix the problem. Some internal data is corrupt and does contribute to the failure of turning off and turning on.
Sony VAIO... | Answered on Sep 21, 2011
Sony VAIO VGN-CS215J/W Notebook Logo
142 questions posted
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
win turn pc screen white move lid up
  • Computers & Internet
