On .325 pitch chain the top plate angle should be 25 degrees, there is normaly a match mark on top of each cutter, the depth gauge should be set at 25 thousands of an inch.
The E version is tooless, so flip out the wing in the centre of the big cover fixing nut,slacken the nut off half a turn, now turn the knurled adjuster in the side cover, down to tighten, up to slacken, there are many schools of thought about the correct tention of the chain, but basically the chain should sit snuggly all round the guide bar, and with a gloved hand pull manually around the bar with out too much force, it should never sag on the bottom of the guide bar.
We have a Husky 435 (two year warranty) that was new last year. It would start and run fine for several days, then nothing--took to warranty service where they replaced the ignition module the first time. Ran for several more days, then nothing again--this time they replaced the carburetor and it seems to working fine from then on. Suspect that Husqvarna has had problems with our ethanol-blended fuels. If you still have warranty coverage, then take advantage. Hope this helps!
A commen problem is flooding the engine.
A good way to start it is to press the fuel pump balloon three times choke it. pull once...pust the choke back in so that its stops choking and give it a few swings then it should start.
i am asuming you have put the on of switch to on.
Hi Hope this link help you a little http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=b091f8d2-6ba8-44df-9037-edddf1788be6&cat=10&TF=epcFrame&assem=148&ignoreHist=Yes&level=1
