All questions need FULL 'make model (what is is)' or we just guess!
Canon imagePROGRAF iPF Error Code 03130031-2F2A
ProPrinting Systems
https://proprintingsystems.com > canon-imageprograf-...
Hardware error 03130031-2F2A means your imagePROGRAF cannot detect the LF home position. It also displays a message 'directing you to restart the printer.
Canon IPF 750 error code 03130031-2F2A
Copytechnet
https://www.copytechnet.com > ... > Canon
Jan 31, 2018 - 2F2A is a Linefeed Error, maybe the Lubricant on the polished Metal Bar becomes sticky, causing the Carrier run too heavy. Clean thoroughly and ...
codigo en ipf 700 -710 03130031 2F2A - Copytechnet
Sep 10, 2019
Tag: 03130031-2f2a - Search Results - Copytechnet.com
Sep 8, 2019
IPF8300 error 03130031-2F25 - Copytechnet
Sep 8, 2019
Canon IPF 710 error 03130031 2F2A - Copytechnet
Apr 30, 2019
More results from www.copytechnet.com
Canon iPF5100 - Error Code: 03130031-2F2A
PrintCopy .info
https://printcopy.info > code=03130031-2F2A
Code: 03130031-2F2A · Description: Feed roller home position error. · Causes: Feed roller encoder film, feed roller HP sensor, feed motor, or main controller PCB ...
Can IPF 750 Error# 03130031-2F2A. Sorry! Canon ...
JustAnswer
https://www.justanswer.com > printers > avaqq-ipf-75...
Dec 13, 2017 - Unplug the power cord from the wall outlet. Press and HOLD the Power Button for 60 seconds. Plug the power cord back into the wall outlet.
1 answer · Top answer: Thanks for choosing Just Answer. I'm Kumar and I'll assist you today. Do you a
tengo un canon ipf 700 que le ha salido el mismo código E161-403E, precisaría una solucion, gracias
I have this problem in a ipf 9100 and I have changed: right and left print heads, MAIN BOARD DIMM ***'Y, CARRIAGE UNIT,M/C RELAY PCB ***'Y what can I do, I really don´t know what to do
