20 Most Recent
Canon imagePROGRAF iPF8000 Printer Questions & Answers
How to get into service mode
with the machine switched off hold down the sheet or roll feed button and the information button keep these pressed and switch the machine on, keeping the puttons pressed until you see an S in the top right hand corner of the display then let go of the buttons, you should now be in service mode. if you fit print heads in this mode the machine will not automaticlly adjust the new heads. you will have to select this in the normal menu.
11/10/2021 7:15:05 PM •
Canon...
Answered
on Nov 10, 2021
Resetting maintenance ctg for canon ipf8000
You can reset it from the service mode it will take you 15 sec but you can use it only for service reasons.
If you reset it there is danger to fload with ink and messed up the whole area.
11/10/2021 7:14:58 PM •
Canon...
Answered
on Nov 10, 2021
Error 03130031-2F1F
03130031-2F1F: Purge motor HP error - Restart printer in Service Mode (Roll/Sheet Feed Button + Information button and then Power On button) to check without Cleaning cycle.
11/9/2021 10:03:18 PM •
Canon...
Answered
on Nov 09, 2021
03130031-2F51
This is a printhead error
Remove the Printhead(s), clean the contacts,and replace in printer . Run nozzle check and try to print.
If you are able to print a few pages then get the same error, the Printhead will need to be replaced.
Good luck
11/9/2021 10:00:41 PM •
Canon...
Answered
on Nov 09, 2021
Error code 03130031-2F13
03130031-2F13 A/D Converter external trigger output stopped
and the problem is main controler
11/9/2021 9:19:43 PM •
Canon...
Answered
on Nov 09, 2021
I have a canon ipf 8000 showing a error
problem in the move of the carriage unit. Check visually if there is any paper inside the machine.
Check and come back later for more information
10/6/2021 3:14:14 PM •
Canon...
Answered
on Oct 06, 2021
Canon ipf8000 error code
Hold down the roll/media button and the info button while turning on, wait about 10 seconds and release roll/info buttons. You should get an S in the upper right corner. That puts you in service mode. Push menu then scroll down to maintenance then right arrow to head replacement. To get out of service mode turn off.
10/6/2021 2:06:06 PM •
Canon...
Answered
on Oct 06, 2021
Canon ipf 8000 Error Code E161-403F
I have had two of my Canon plotters give this error.message, I had to manually move the carriage unit and replace the printhead. On one of the plotters the error message returned, on the second plotter I was able to go into service mode where it asked me to replace the printhead. I just went though the motions since the printhead was brand new and I was able to get the plotter to function correctly.
10/6/2021 2:05:38 PM •
Canon...
Answered
on Oct 06, 2021
Hardware error
Follow these steps :
Cause: The Voltage of the print head is abnormal.
Problems can be with:
-Printhead
-head relay PCB
-Carriage relay PCB
-Main controller PCB
Steps to be followed:
1. Replace the printhead.
2. Cable continuity check.
if continuity of the cable between the head relay PCB and the carriage relay PCB is abnormal, replace the cable.
3. Replace the head relay PCB.
4. Cable continuity check.
if continuity of the cable between the carriage relay PCB iand the main controller PCB is abnormal, replace the cable.
5.Replace the carriage relay PCB.
6.Replace the main controller PCB.
9/9/2019 12:15:09 PM •
Canon...
Answered
on Sep 09, 2019
03130031-2F52 error
my printer suddenly stopped working and is showing the following error code 03130031-2F52. If anybody know how to fix it, please email me at
[email protected]. thank you.
11/7/2018 6:41:26 AM •
Canon...
Answered
on Nov 07, 2018
