My Kenwood dishwasher KDW24FI/B has worked fine for approx 2 years. But now when I put my dishwasher on, the cycle never seems to end. After a few hours of running I opened the door to find the tablet hadn't dissolved but lots of steam coming out. I tried 2 more times and the same thing happened. The pump is working and everything seems ok. After reading the manual I have noticed the salt and rinse aid lights are iluminated. I have never put salt or rinse aid in since I had the dishwasher so this may be irrelivent. Can you help please?
go to searspartsdirect and get an image of the locking section and the parts and prices will be displayed. if this has been helpful post me back a 4 thumbs up rate .
The water valve may look fine but the solenoid may not be opening to allow water in. You said that everything else works fine except no water supply to the dishwasher. This sounds like a bad soleniod valve. Check for continuity on the valve with an ohms meter after you start it. Be careful.
The micro switch is bad. I had the same problem cleaned the switch a few time (nd bought some time) but in the end I moved a switch from a cycle we did not use to the start position. Cost was nothing but my time (must have skills in soldering PCB assy). Worked fine since, almost a year now. However I have had several unrelated problems and would thing twice before putting any major money into this unit. In the 3 years I;'ve had this unit I've fixed the switch, installed a new pump assy and put in 2 thermal switches (unit appears dead when they go bad). I've done all this myself and the bills would be between $700 nad $1,000 to call service.
My dishwasher isnt working anymore after i cleaned the filters?
i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere? It is a Whirlpool ADP 5540 thanks for your help ****
the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
