I have a squealing in my engine. I have checked the belts and they are clean and tight. All fluids are full. The noise is not effected by turning the steering wheel, but it starts when you start the car and gets louder as you accelerate. It does not stop at any point until the engine is shut off. Any suggestions?
Probably should replace the belt. A worn belt will squeal sometimes.'
Another thought is the belt tight enough A belt that is too loose will squeal under stress .
Without hearing the noise I can't tell you for sure but take a spray can of WD40 and with the engine running spray some on the belts if noise goes way that's your problem, if not check the A/C (if you have A/C) the compressor may be binding up causing the belt to squeal due to friction from the tight compressor. To check the compressor remove the belt and turn the A/C pulley by hand (should turn freely) next turn on the key (do not start engine) turn on A/C then turn A/C pulley by hand again. It will be harder to turn but still relativity easy. If it is hard to turn it is beginning to bind.
I have been having the same problem with the alternator belt squealing, most noticeably, when using the heater fan , accelerating, turning the headlights on. I have a 1997 Toyota Tercel CE 1.5L 4cyl with no A/C. I just tightened the belt tight enough that there is no give to the belt and it does not squeal anymore.
I also used a Goodyear Gatorback from Napa belt which seems to be nice and quiet when tight enough.
belts were put on too tight or have gotten too loose after they were replaced. the nuts that hold the parts in place may not have been tight enough causing the parts to move , which loosens the belt. maybe the belts were stretched too tight when replaced,....... either will cause squealing...good luck
power steering pump... with a lil luck it may just need tightened( belt anyways) but with even more luck it could just need some fluid. sure thing it seems to be power steering.weather its bad or not depends on it the belt is tight and if its full on fluid. let me know ,sammy
The power steering pump is normally connected or driven by the engine with a V-belt. A loose belt can cause squealing as soon as the power steering come under load (e.g. steering left or right while stopped).
Check the tension on the V-belt directly connected to the power steering pump. This may need replacement.
Try turning the wheel when standing still with the engine running.
If it is tight check the obviouse, has the power steering belt come off. If not check if there is fluid in the steering pump resavour. If the belt is on and you have fluid you may have a bad pump.
I hope this helps
Regards
Sam
