Our KitchenAid dishwasher has been working great until just recently. It has started to leak small amounts of soapy water about half way through the process. I ran an empty load and it didn't leak. Ran...
Hi
Thanks for using FixYa. If you
have nuisance water leaks around the base of your dishwasher, you may be using
a detergent that is causing too much suds. Cut back on the amount of detergent
you use, and see if that makes a difference.
Water that spills through the door
vent is usually caused by improperly loading dishes. Leaks from the door itself
may be caused by a faulty door gasket or door tightness adjustment. you should
check the main tub seal, the door latch, the door gasket, the water-inlet valve,
and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet
up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose
connection. Remove the lower front panel, and check the hoses. The pump seal
may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If
this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or
else revert for further assistance.
Thanks
Rylee
Answer 2 (Door seal replacement)
Hi
Thanks
for using FixYa. If you have nuisance water leaks around the base of your
dishwasher, you may be using a detergent that is causing too much suds. Cut
back on the amount of detergent you use, and see if that makes a difference.
Water
that spills through the door vent is usually caused by improperly loading
dishes. Leaks from the door itself may be caused by a faulty door gasket or
door tightness adjustment. you should check the main tub seal, the door latch,
the door gasket, the water-inlet valve, and the fill and drain hoses.
may be defective, too; replacing this is a job for an appliance repair person.
The door seals on this Kitchenaid dishwasher are pressure fit into a metal
channel that runs along the inside of the wash tub.
To
install, simply remove the old seal paying close attention to which way it was
installed, apply a bead of adhesive inside the channel, then install the new
seal in the correct direction. A test fit prior to applying the adhesive is a
good idea and if you are having trouble with one side being to long, try
folding the seal in half, take hold of the looped end, and insert it under the
door latch. The reset should go in properly. The new seal will be a tight fit
which is the way we want it so it may take some force to get it fully seated.
If the door is hard to close, then the door seal needs some more work.
Please do
accept the solution if the issue is resolved or else revert for further
assistance.
Thanks
Rylee
Same dishwasher leaking from bottom of the door.It is not the door seal as that seems smooth and clean. It seems that it starts after the agitater or sprayers are activated. Help
