20 Most Recent KitchenAid 24 in. KUDP02CR Built-in Dishwasher Questions & Answers
KITCHENAID DISHWASHER REBOOT - YouTube
? 4:17
www.youtube.com/watch?v=XJnzzXJcOV4
Sep 17, 2012 - Uploaded by DIYAPPLIANCEREPAIR How to reboot your Kitchenaid, Whirlpool, Kenmore by Whirlpool dishwashers control board. ... Up next. Dishwasher Repair will notstart - Repair & Diagnostc - Kitchenaid - Whirlpool ... Kenmore Elite Dishwasher blinking light Control Board FIX - Duration: 1:37. by ... Dishwasher Buttons Not Working?
KitchenAid 24... | Answered on Oct 19, 2015
Check your water inlet for the right pressure and then the water float valve for the right amount of water in the tub for washing. The tub has to have the right amount of water in it to pump it up to the top. It is also possible that the pump has debris in it that is restricting the flow. Clean out the screens and check the bottom of the washer tub for debris at the pump inlet. Use white vinegar to clean out your washer. Start your washer - open the door and pour in a lot of vinegar. Let it run for a few seconds and stop it. Let the vinegar work on the scale and debris. Start and stop it several times during the day - not completing the wash cycle until in the morning - after it has sat with the vinegar 10 -12 hours.
KitchenAid 24... | Answered on Mar 05, 2014
Note: Electricity can cause serious injury even Death.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
After Isolating your appliance from the main switchboard,
Check that the tap is on feeding the line to the Dishwasher.
Check other taps in the house to see if your getting water to the house from the mains.
If its hard plumbed and the water is on, and still no water... check the inlet filter on the back of the dishwasher. make sure you have turned the power off first.
This could be blocked / obstructed with buildup grime from the water mains.
After cleaning the filters/ Checking the water supply and restarting the Dishwasher and you get the same error message you will need to call a serviceman to analyze the problem further. DO NOT attempt to dismantle the Dishwasher yourself unless you are a registered electrician or a qualified serviceman.
If its still under warranty call the manufacturer or the store it was purchased from, they can arrange a serviceman for you.
Good luck and Take Care
KitchenAid 24... | Answered on Feb 07, 2014
Try this, let the dishwasher run the quick-clean up cycle if it still can.
Then turn it off at the wall. Unplug it from the wall.
Give it a moment.
Plug it back in, turn it on at the wall.
with a bit of luck it should be up and running again. if not...
Check the door is closed properly, it needs to click shut fully before the dishwasher will start.
If all that fails, we could assume its more serious, there are different courses of action to be taken...
If its under warranty then make the call to the manufacturer or store and go from there.
DO NOT try and fix it yourself unless you are a registered electrician or serviceman.
Good Luck
Hello, cit
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
KitchenAid 24... | Answered on Oct 27, 2011
This means the touch pad sense a stuck or shorted key. Try pushing in all the keys to make sure there not stuck. If not, the touch pad needs to be replaced.
The screws around the door come out and the assembly will slide forward. All plug and play type connections and a few 1/4 screws. The repair is really straight forward. Good luck with your repair friend
KitchenAid 24... | Answered on May 19, 2011
The timer/control board has gone bad and will need to be replaced...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
KitchenAid 24... | Answered on Mar 18, 2011
KitchenAid 24 in. KUDP02CR Built-in Dishwasher Logo
121 questions posted
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Dishwashers
Most Popular Question
machine start ka dishwasher
  • Dishwashers
