Gemini XL-500 Turntable Logo
Posted on Aug 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a replacement cartridge for the gemini xl 500 ii series and i can't seem to find it in any stores or online.
Bryan Daugherty
Level 3:
Master:
  • Master 344 Answers
  • Posted on Aug 03, 2010
Bryan Daugherty
Master
Level 3:
Master:
Answers
344
Questions
0
Helped
73089
Points
1122
Maybe this will be of help?
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=GEMSXL500II
What do I need regarding preamp/cartridge matching?
Cartridges require no special pre-amp. If your amp has one built in the sound from the deck will come out at the same level as other functions. If the amp has no inbuilt pre-amp you will still hear sound (if the cartridge is working) only the volume will be too low to listen to. All you need do is connect the record player to the amp and see if you can hear the sound. If you can't then you need a magnetic cartridge pre-amp. By the way if you need a new cartridge you don't have to stick with a Gemini make. You can use any one you want as long as it will fit into the headshell. There some better makes of cartridge out there, that will give better sound quality. It all depends on what you want to spend on a cartridge!
How to fix flutter & wow on a Gemini 500 XLii direct drive turntable
Direct drive turntables have electronically controlled speed. If the records you are playing are warped (not flat) that will cause wow & flutter. If that's not the problem then you might try connecting the turntable to a different power outlet using a long extension cord. Failing that, the turntable needs repair.
Where to get a needle for Gemini XL 500 II
Look at the cartridge make and model number fitted. Put that into Google and the type of stylus needed will show up.
1helpful
I have tried too hook up my Gemini XL-500, to a Sony Digital Audio DTS discrete 6ch Amp , but get very low volume, tuner & cd dvd, volume is fine, does this have anything to do with the ground?...
No! The amp must have a magnetic cartridge pre-amp to increase the sound level. If it has one it will say "phono" on the inputs on the back and have a "turntable" - or "Phono" selector switch. If it doesn't have one (many new surround amps don't) you won't be able to play it properly untill you get a "magnetic cartridge pre-amp". This will make the signal loud enough to be used on a normal aux imput of the Sony.
2helpful
2answers
Turntable will not hold pitch,speeds up or slows down.
try replacing the drive belt with brand new one and see if this improves the situation
Gemini xl 500
on top of the pitch control there is a small hole, in this hole you can use a small screw driver  and turn it left and right to free any dirt inside this is the master pitch control
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
