SOURCE: Belkin G Wireless Router Not funciontoning: Power Light is Off
Its dead Jim.
I had one of those. Dead.
You can try hitting the reset button. Looking at the back there should be a small hole with a tiny button. Use a staightened paper clip or other object to hold it in for at least 30 seconds. That should set it back to factory defaults.
Doing that brought mine back to life momentarily , but it kept going out after a couple of hours and I had to repeat the process until it finally gave up the ghost for good.
SOURCE: Configuring Belkin Wireless Router
You choose a wireless router so you need to install in some freequency. You can choose the freequency by the list like 2.4 G.Hz ect. then just select the link & fix threre working ares / type. Avoid the command prompt. use bessic settings your user manuel help you further.
SOURCE: Belkin Router problem
A red light on your belkin router means its already busted as you decribe other lights are not ON at all. In all other types of modems and routers Red LED light on it mean synching up and if more than 20 secs with a red light is already considered busted.
Note: You may also check your phone cable rj11 , power surges, defective phone jack.
SOURCE: wireless light flashes red when my laptop tries to
if your using lenovo and is an Ideapad Y series or a G series Laptop look for the program called lenovo readycom in the control panel add remove programs if you have XP and if vista go to control panel and look for programs and features this goes the same with win7 just uninstall Lenovo Readycom 4.0 or 5.0 and as well look for a program called network magic if that program is present then uninstall this as well then restart your laptop, try connecting again ^_^ happy surfing ..
when you upgraded did any settings from your isp change like passwords or usenames that your router may not be registering at your isp's server, or the line speed that you are now getting is not suported by the router.
type 192.168.2.1 in your web browser and check the connection settings.
