HP Officejet Pro 8500 Printer - some times the bottom line on a page will print and some times it won't. If I print multiple copies of the same page, say 3, 2 will print correctly and one will not. I thought it had to be something with Word or Excel but it sometime prints the last line and sometime it does not so this points to the printer.
SOURCE: HP Officejet Pro 8500 has a paper jam. Can't get
Hi! I will be glad to assist you in this issue, here is the link that will fix the issue:
Paper Jam' Message Displays on the All-in-One
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01617494&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Carriage Jam' Message Displays on the Control Panel Display
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01618201&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
SOURCE: does HP 8500 scan multiple pages into one file?
yes if you use a pdf editor or office suite.
SOURCE: My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
SOURCE: no connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Testimonial: "superb"
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
