Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
Posted on Jun 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fault F 05
F05
Anonymous
Level 3:
Brigadier General:
  • Master 4,090 Answers
  • Posted on Jun 26, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
4090
Questions
0
Helped
1184353
Points
12747
This error relates to an object or piece of clothing blocking the pump, Clear it by taking off the inlet hose and releasing the object then all should be ok again
Please rate my help++++Thanks for using FIXYA
3helpful
2answers
Hotpoint aquarius fault code f 05
  • F05 - Pressure switch jammed on full
  • Thing to do check pump is not blocked and clear it then reset machine by unplugging for 5 mins and plug back in if still gets error F 05 then you need a repair call out. hope this helps.
Machine has a fault code co me up on display F-05
F05 - Pressure switch jammed on full - Check pump for blackages
The fault is associated with drain out (pump blocked or restricted in some way).
3helpful
Fault code f-05
Error code F05 denotes the pressure switch is jammed on full.
Remove lower rear cover of washer.
Remove the large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
2helpful
Does not spin fault code F-05
Error F05 means that the pressure switch has jammed on full.
Do the following.
Remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose on to pump, and check for blockage or obstruction here as well.
Hope this helps with your problem.
19helpful
4answers
3helpful
Fault f05
F05 means pressure switch jammed on full, firstly check that pump is working and that there is no blockage anywhere,
if it still does not work, then you are going to have to call an engineer.
Hope this helps.
Please leave feedback.
2answers
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Indesit we125. F-05 comes on screen. What does this mean?
Hi.
F05 mwans pressure switch jammed on full, check that pump is working o/k, if it is, and still showing fault, then you will have to call an engineer
Hope this helps.
3helpful
Hotpoint Aquarius WT740 Fault Code F-05. What does this mean?
Hi. F05 means pressure switch jammed on full.
Check pump for blockage and that it is working, if no joy you will have to call an engineer
1helpful
NV-DS55B panasonic digital video camera.
Exactly the same problem as everyone else. There's bound to be someone who can offer advice on what to do. The camera obviously recognises the fault as F05, but where can you reference the remedy to this F05 code? It's not in the manual as far as I can see
Top Ariston Technologies Washing Machines Experts
ZJ Limited
ZJ Limited
vince
ADMIN Andrew
ADMIN Andrew
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
