20 Most Recent Ariston Technologies AW129NA 16 Lbs Front Load Washer Questions & Answers
2answers
Washing power/fabric conditioner holder needs removing to clean
This video will show you how to keep your soap draw clear and how to service the parts Please remember to subscribe to our YouTube channel for all appliance tutorials a 4 THUMBS rating is appreciated for answering your FREE question.
7/30/2013 1:14:31 PM • Ariston... • Answered on Jul 30, 2013
0answers
Ariston aqxf 125
Be the first to answer 5/22/2013 9:45:05 AM • Ariston... • Posted on May 22, 2013Be the first to answer
5answers
Washing Machine Door will not open
it is poss that you pressure system has not released, and this can keep the door closed. Unplugging it will not cure this fault. It is also poss that you have a blocked filter or waste. Unfortunatly has you are older people I would call an engineer
5/30/2012 11:12:40 AM • Ariston... • Answered on May 30, 2012
0answers
0answers
The On-Off door lock LED
Many times faults like this can be cured by Uplugging the washer from the mains power supply and leaving for 10mins. Also check all filters, drain and supply lines are clear and not kinked.
5/4/2011 8:44:19 AM • Ariston... • Answered on May 04, 2011
How to replace a door
Hi.
The procedure is quite complicate, because the seal is secured to the front panel, and you will need to remove top panel, detergent drawer and access control assembly
  1. Disconnect appliance from power
  2. Remove the door, held by two screws located on the rear side of the lid.
  3. Lift the top panel, held by two screws at back.
  4. Undo the two screws joining the detergent dispenser to the inlet valve.
  5. Undo the two screws located at the front corners. So to release the fascia and dispenser.
  6. take out fascia and the dispenser alltogether and put it on one side. Take care to not disconnect wiring and do not drop parts.
  7. Release the retaining wire that keep the seal secured to the front panel. Look after it, you will need it again.
  8. Undo the two screws that hold the front pane. They are located on the front side.
  9. Remove the kick panel
  10. Behind the the kick panel you will find the two screws that will release the front panel, remove both of them.
  11. Disconnect the door switch conntector.
  12. Lift the front panel. You may need to help yourself using a putty knife.
  13. Remove the clip with two hooks inside, it is located at about one o clock. This will finally release the seal.
  14. Remove the seal and clean the area where you will fit the new seal.
  15. Start mounting the seal from the lower part on the right, at about four o clock. You will notice the seal matching.
  16. Put back the retaining wire usingf long-nose pliers to put the wire in tension.
  17. Reassemble the washer in reverse order.
Unfortunately we do not have step by step pictures. I hope that my instructions had been enough clear and detailed.
Regards.
4/8/2010 3:51:44 PM • Ariston... • Answered on Apr 08, 2010
2answers
Washing machine keeps chipping out
Take out the filter and wash it thoroughly, also flush the outpipe to make sure the whole system is clean. Does it give you an error code?
2/2/2010 10:43:15 AM • Ariston... • Answered on Feb 02, 2010
My Ariston A1636s washer still washes but has
SOUNDS LIKE THE HEATING ELEMENT HAS GONE
1/9/2010 5:48:54 AM • Ariston... • Answered on Jan 09, 2010
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
1/20/2009 6:38:42 PM • Ariston... • Answered on Jan 20, 2009
Closed door
Dear babmat: just now got your question. We are very satisfied with our ARISTON Washing Machine. I trust that that is what you are inquired about? I had the same problem the first time. This locking occurs when one opens or tries to open the washing machine door too soon!!!! It has to be left alone for a few minutes. When I waited and later tried again to open the machine, I did not have a problem.
Just wanted to leave this note for anyone who encountered the same problem. You, yourself, hopefully, might have gotten that answer and the problem fixed in the meantime!?
Greetings, handinovice
11/1/2008 4:46:57 PM • Ariston... • Answered on Nov 01, 2008
Maytag front loader door will not open
try pause/cancel twice to open door open detergent disp look for a plastic string and pull it
12/31/2007 12:16:46 AM • Ariston... • Answered on Dec 31, 2007
How we get off the demo function?for ariston avxd109
Hold power up and start program together for 1 second then it says DoExit
12/22/2023 5:03:55 AM • Ariston... • Answered on Dec 22, 2023
Ariston washing machine model AR7L 125, blinks light and does not start operation. What should I do?
First try a power reset. Disconnect from the wall socket for 30 minutes. Press and hold the power button for 2 minutes. Plug the machine back in. Information in the link suggests you may need a new control board. They are expensive, so dealer diagnosis is advised. https://www.google.com/search?q=Ariston+washing+machine+model+AR7L+125%2C+blinks+light ..
6/23/2023 11:40:34 PM • Ariston... • Answered on Jun 23, 2023
What is error f19 in Ariston Washing Machine rdpg96207 s 60 hz and how to fix it?
https://www.needapplianceparts.com/aristonerrorcodes.aspx
9/10/2021 10:16:11 AM • Ariston... • Answered on Sep 10, 2021
We have an Ariston washer received error code f05. Where is the pressure switch. How do we reset
Pump fault or more likely blocked filter try cleaning should reset it self
5/6/2019 5:36:12 PM • Ariston... • Answered on May 06, 2019
Ariston Technologies AW129NA 16 Lbs Front Load Washer Logo
23 questions posted
Top Ariston Technologies Washing Machines Experts
ZJ Limited
ZJ Limited
vince
ADMIN Andrew
ADMIN Andrew
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Ariston Technologies Washing Machines
Most Popular Question
washing machine door will not open
  • Washing Machines
