it is telling me to fix the helix components when i plug my sansa into rhapsody. above it says to clear the que. how do you do that?it is telling me to fix the helix components when i plug my sansa into rhapsody. above it says to clear the que. how do you do that?
You can't post conmments that contain an email address.
The foam filter can be hand washed, squeezed and them dried.
The pleated filter really never seems to loose it stall smell after cleaning. It's best to tap it against the hard ground to free the dirt.
Washing it can cause odors.
the pulley will not remove very easily , it wold require removine the milk stool, motor and some other parts, not the easiest hing to do especially if not needed, the helix you removed, take a look at it , the sloped ends of it should create a pretty sharp angle, then a 90degree drop off, the slopes om the pulley should be the same, they should not apppear to be rounded off,helix is probly 10 bucks if needed and if its at the helix that you see the "slipping" and "clicking noise, before condeming the tranny i would start with tthe helix, if after re-installing it it still clicks up and over pully perhaps try adding another spacer under the bolt before tightening. the idea behind the pulley and helix is that depending on rotation of the transissiion, the helix "pushes against" the pulley adn spreads the brake plate, releasing the brake allowing the tub tospin freely
