Kyocera CS-2550 Black and White Copier Logo
Posted on Mar 27, 2008
Scanner - memory is full
Scan 60 pages and scanner states memory is full... how do I correct this problem... In the pass I have ran more than a 1000 copies before this notice would pop up...
Anonymous
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on Aug 07, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
29
Questions
0
Helped
31278
Points
41
In comant senture u can make the scan megabyte more
  • Anonymous Aug 07, 2012
    in comant senture u can make the scan megabyte more
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Apr 17, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
4229
Points
6
A KM-2550 has 64 MB RAM built in. I believe less than 30 of it is for image storage. You may be able to lower your scan resolution.
Best solution is to add more memory. Look for a Kyocera compatible 100 pin dimm (don't buy from the manufacturer). It will read 16 MB to 256 MB sticks. You have to take out 6-8 screws holding on the part of the back the sticks out on the upper left. Make sure after installing you print a status page to make sure the memory was recognized.
2answers
How do I scan multiple pages to one file using a deskjet 2512 printer/scanner
On the control panel, select scan to computer and choose PDF.
If you are using the sheet feeder, it will scan all pages and create one file with them all.
OR
If you're using a scanner glass, i.e. one page at a time, when the first page finishes scanning, you will get a message asking if you have another - answer YES and follow the instructions (basically that means place next page on scanner glass and hit OK/Continue). Rinse and repeat until you've scanned all pages then answer NO.
You should find a PDF file in your HP Scan Folder usually named "scan.pdf" unless you've changed the settings. (If there is/are already scanned files in that folder, they will have consecutive numbers, e.g. "scan001.pdf" "scan002.pdf" etc
How do I download program for wolverine pass 200 portable scanner?
The Wolverine Data Pass-200 portable scanner uses a micro-sd or sdhc memory card to store scans. After you scan something, you can remove the memory card and plug it into a memory card reader connected to your computer and view/download the scans.
Alternately, you can connect the Pass-200 scanner to your computer via a USB cable and access the scans like you would with a digital camera. Look for a new removable storage drive to appear on your computer once you connect the Pass-200. On the new drive, look for a DCIM folder and 100DEDIA folder for the scans.
As far as I can determine, the Pass-200 does not conform to any scanner interface or API standards such as Scanner Access Now Easy (SANE),TWAIN, Windows Image Acquisition (WIA), Image and Scanner Interface Specification (ISIS) so there is no driver or software to install to scan using the computer.
2answers
Change orientation on canon dr-7580 scanner
Two step process, scan and save the image, then print and select landscape
3answers
Canon DR-7580 will scan first 12-14 pages rapidly then pauses, scans a page, pauses, scans a page... I have the exact same scanner hooked to another pc that is exactly the same.. and it flies through the...
Your hard disk must be almost full. Direct the scanning software to send data to a hard Disk location where you have enough space.
S. Mohan, India
When I copy or scan a picture a line is down the center of the picture
When scanning the page it is passed over the scanner, a mark on the scanner will then be copied down the full lenght of the page. I not sure how much access to the scanner you have with this model but you need to examine the scanner for a spot of dirt/correction fluid and clean it, you may need to scratch it off with an old credit card or similar
1helpful
I have got scanner 1000 but cannot scan the barcodes i have got. like TA010304, when i scanned it, other weird stuff would appear like 06^OX... anyone can help me? Thanks.
Hi there, you may check the settings of your scanner software, go to start>programs and check the scan software utility and from there check the settings of the scanning page/are so that it would see those barcodes you need.. or may lighten the scan settings as well.
Scanning limited to 11 pages
You must have your scanner resolution set way up
1helpful
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
1helpful
Scanning speed slowed...
did you change your scan resoulution? The quality of your scans will determine how slow it will pass through. another thing to check is weather it is scanning both sides, another option in your scanner properties.
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
