I just changed the battery in my 2000 chev silveroda, 2wd pick up, v-8. Now it turns over, fires and stalls, what is the problem?
You need to reset the security system. Turn the key on. The security light should be flashing. Leave the key on for 11 minutes. The security light should stop flashing. Turn the key off. Turn the key on. Leave the key on for 11 min. again. Do the process a third time. It should start and run on the next key turn. ( also hook a battery charger to the truck while doing this 30 min. procedure. If the battery goes low at any time you will have to start over.)
