Epson Stylus D88 InkJet Photo Printer Logo
Posted on Apr 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer says parts our out of service date and suggests to configure user manual. Help please.
Anonymous
Level 3:
  • Master 677 Answers
  • Posted on Apr 05, 2010
Anonymous
Master
Level 3:
Answers
677
Questions
0
Helped
239355
Points
1685
Found this on the web site., link below. If anybody find this information
Helpful, pls rate me.
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
Parts inside your printer are at the end of their service life “Today I had the joy of fixing an Epson Stylus C46 UX printer.”It had the following error: “Parts inside your printer are at the end of their service life. See your printer documentation.”
After a little searching I discovered that most people were saying that “It is simply not worth repairing”, however, I took that as a challenge, and decided that if I was going to throw it away anyway I might as well try to fix it first.
Before long I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues. This is the process I used after reading details on that page:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
  3. Unscrew the screw at the back of the printer.
  4. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
  5. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
  6. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
  7. It is recommended that once you have done this, you let them dry.
  8. Now return the pads back into the printer.
  9. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
  10. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
  11. Download and install the SSC Service Utility for Epson Stylus Printers.
  12. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  13. If it asks if you replaced with the pads; say “YES”. Then close the window.
  14. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  15. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”.
  16. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Done! Additional troubleshooting… If you have problems with paper feed, take it apart again, check everything is in place correctly, push things together tightly, and put it together again. If you have trouble with print quality, open the lid, clean any ink residue, use the SSC Service Utilitiy to clean the heads.
Thanks and Good Luck Please Rate Me
My olivetti prt 100 is not cutting the paper automatically and I cannot find the user manual. Please help
first check the software part if driver with paper cut is installed or else try olivetti service centre
Got casio qt2000 till, using hospitality 1.35 build 181. Single connection to PC com3:, no printers terminal only and cash draw. Simple single bar senario, Drinks, Read takins and item groups at end...
I think you enter date in std Casio format: PGM1 mode, Type YYMMDD then press X/TIME button
If you go to Z mode and try a report, what happens?
If anyone needs a manual for a Casio QT-2000, C-tech collective have User/ Programming, service manuals here: http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
2helpful
2answers
I need an operational manual for canon smartbase MP360
You can get the user manual for this printer from this link, just click HERE and proceed with the download.
Print date on photo
see page 55 of the user manual - link below
Here is the user manual http://www.fujifilm.ca/documents/Fuji_Z2_CM.pdf
  1. Press the “w” button to turn the camera on in Playback mode.
  2. Press the “MENU/OK” button to display the menu on the LCD monitor.
  3. Press “a” or “b” to select “¸” PRINT ORDER (DPOF).
  4. Press “c”.
  5. Press “a” or “b” to select “WITH DATE” or “WITHOUT DATE”. Selecting “WITH DATE” will cause the date to be imprinted on your prints.
  6. Press the “MENU/OK” button.
Note: When selecting the “WITH DATE” setting, the date is imprinted on your shots using the Print Service or a DPOF compatible printer (depending on the printer specifications, the date may not be printed in some cases).
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
3answers
Hp laserjet 4250tn printer 49FF95 Service error
Hello
Thank you for using FixYa for your problem
It should be taken to an authorized repair centre for a repair estimate. Very few printers have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
6helpful
2answers
Users manual for the Canon ir c3220
http://www.service.canon.com.au/manuals/ufrv130.pdf Give this a go mate.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
