You can find all the drivers Except the sm bus controller on Sony's web site. If you have a ATI Graphics board, go to there site to get the SM bus controller drive.
to install SM BUS controller driver you need to install chipset driver of your motherboard. It is also used to install Audio devices. Go to the compaq website and look for your make model and install the requied driver
Go to dell's website, but in your model number and ownload the driver for your operating system that says "chipset", this driver pack will have the sm bus controller drivers in it. I looked in the drivers for XP and the second one down actually states it is for the sm bus controller. http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Hi
This is the software issue. Need to install the appropriate software to reslove this issue.
1.Ethernet controler - Need to install the chipset driver and the Lan driver
2.Pci bus device - Chipset driver
3. sm bus controller - After installation of the Chipset driver - Right click on the sm bus controller and update the driver - select install from specific location - i will chose the location- Select the model and hardware type as thermal sensor
next - follow the instruction.
4. video controller - Need to install the VGA or Display driver
5. video controller (vga compatiable) - Need to install the VGA or Display driver
goto to system devices look for the question mark, right click, and try reinstall the drivers again, this should normally work and reboot your machine and the drivers should be there.
may be the bus driver you are trying to install may not be compatable for your machine, check with the user manual to see what bus derivers you can install
