20 Most Recent
ATI Amd Athlon64 X2 5000b 2.6ghz Socket Am2 Cpu brisbane Core Processor Questions & Answers
Ms bus controller
It's SM bus controller, and you want the newest chipset drivers for this.Go to the maker of your motherboard or the maker of your system like dell and download the chipset driver.Posting SM bus controller is not a question.
My HD 4850 fan is
Your heatsink fan on the graphic card is failing and the motor is going down hill, now saying it has completly stopped..,.. that means the fan motor is done for and need to be replaced to avoid further damage to your graphic card. Would reccommend you not using your graphic card until a new heatsink fan is replaced otherwise you can fry your GPU and suffer a complete loss.
My graphics card will not
How did you get your drivers and graphics? Did you install the whole package? What is the Asus model #? How much Ram do you have? I'm going to do a little research but let me know what you have.
Dave
HIS radeon HD 6750
Are you certain that your mainboard is PCIE 2.1 and not PCIE 2.0?
PCIE 2.1 cards like yours will not work on a 2.0 mainboard (2.0 cards will work on a 2.1 board, however) If this is the case, you will need to get a compatible card.If this isn't the case, have you tried this card in a different PC? It could also be that the card has a problem.The last possibility is that there are power issues. A couple of possibilities:
- An external power connector (6-pin PCIE direct power to the video card) is unplugged. Check and re-test.
- Your power supply (PSU) doesn't provide enough power to your graphics card & the rest of your system. Check your PSU's specs against the specs for your card. HIS recommends a minimum 450W PSU, and I would recommend a good quality Antec, Corsair, or PC Power and Cooling or Cooler Master product in the 500W range for this card.
- You got a bad card, or else it shorted out, etc. during setup or installation.
Gigabyte vga card d33006
your card is the gigabyte GV-RX195P256D-RH and you can download the drivers from here https://www.gigabyte.com/us/Graphics-Card/GV-RX195P256D-RH#support-dl-driver-vgadriver
How do i upgrade My GPU in a dell Optiplex 745 Desktop Low profile?
Chris, let's back up just a second. Before you go for a new graphics card, just what problem are you trying to solve? If you're watching TV, the graphics you already have are likely just fine.
If you feel your system is slow doing regular stuff, more RAM may help, or a faster disk drive.
About the only thing a fancy graphics board will get you is faster screen updates for gaming. If that's what you're after, you may want to consider a full system update, with standard height case, 500 watt power supply and all of that....
