20 Most Recent
Dell Inspiron 1501 Laptop Questions & Answers
Hot to remove bios pasword?
To unlock your BIOS you have to remove your BIOS battery for few minutes which is onboard, then replace the BIOS battery again on the motherboard will not only reset the BIOS password to default but will put all the BIOS settings to default. For which you will have to reconfigure your BIOS settings, but remember any wrong setting in the BIOS may damage your laptop.
The sound icon has disappeared from the task bar.
hello from a few days ago I was working on my laptop and suddenly reboot. but now get a message that is:sis UNDI, PXE-2.1copyright PXE BootROM v1.09f - ZL5_0324 Use BEV/BBS=== Press <Esc> to bypass LAN check. ====him and tried to boot from the CD drive. order to retrieve information or other cases formatting. but when the process goes to the information is not in the hard disk.
Master password for wifi
This Password creates your data file using the password you provided when you
first launched the application. This password is not kept anywhere and
it is never logged. Furthermore, there is no "back door" mechanism to
recover your data or password.Try to restore your data backup file..
Media test failure, no os
Your
hard drive is missing from the system. Or, just does not recognize it.
The
obvious - Remove any USB devices like drives and any media from disc player.
Its trying to load, but can't find bootable hard drive, CD, or USB...
Remove
the hard drive and re-seat (reconnect). Check BIOS by pressing an F key
during boot. Look on the screen for correct Function key. Might be F2 key.
Verify BIOS recognizes the drive. It must be listed! There is no going
forward if it's not. Check boot order and make internal hard drive first.
Save and restart.
My volume icon on the task bar has disappeared, how do I get it back
Open the TASK MANAGER, open the PROCESSES tab, highlight "explorer.exe", click on "end process", Open "file", "New Task", Type "explorer" without quotation marks. OR Control Panel, Sound, depending on your OS, You will find a box to show tray icon. If it is checked, uncheck, apply, then check, apply. The Task Manager will remove stored icons that fill the program, and restart the icons.
I forgot my loggin password
Unless you know how to hack into it, you should use a hard disk recovery tool to back up your files and re-install windows.
