SOURCE: Crackly Headset
I had same issues but hadnt bothered install the driver cd that came with headset I had let XP find it.. so just installed the CD and had to upgrade to latest windows messenger, then replug ur headset in or pull out and reinsert usb and all should be fine :)
SOURCE: Lifechat LX-3000 refuses to let me speak
I had the same problem which I traced to a manufacturing fault. I had to break into the control box halfway along the cable (you will defintiely void warranty doing this!) The cable connection from the headphone to the control circuit was not properley terminated (some cable insulation was melted through to bare wires). You have to re-terminate this cable so you need skills cutting/stripping wires and resoldering, and if you attempt any of this don't expect to be able to complain or ask for a replacement under warranty.
SOURCE: How do I get microsoft live chat wireless headset with skype?
Normal
0
Make sure you select the wireless when you do the setup.
Also send this to your family
and friends so they have their computer setup properly.
Web Camera’s have to be
setup on the program they are to be used with.
Just installing the camera on your computer does not set it up to
broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/)
set it up as follows:
The camera and audio should function properly. Your friends and Family will now be able to
see and her to you.
Hope this helps.
Bud
SOURCE: I have life chat lx-3000 headset that was working
My guess it's something in the cabling of this device I think it is cheaper to buy a new headset with the same quality. I think that that best solves your problem.
