Sebo Automatic X1 Bagged Upright Vacuum Logo
Posted on Feb 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Light saying bag full and clogged have changed bagand checked for blocks cant find anything.
Anonymous
Level 3:
President:
  • Master 389 Answers
  • Posted on Mar 01, 2010
Anonymous
Master
Level 3:
President:
Answers
389
Questions
Helped
247438
Points
1343
OK - blockages are not always obvious (especially if they are deep within the flexible hose). One thing you can try is to remove the flexible hose from the top of the bag compartment and then switch on - if the red light goes out, there's a blockage in the hose. If the light stays on, there's almost certainly a problem with the main circuit board (for which you should get professional help) but that would be extremely unusual. If you need further help, please post a reply here and I'll do what I can.
2answers
I have windsor s12 red light for bag is full is on and it's not clogged. what next
Check the line going from the bottom of the vacuum to the bag, it may be clogged. A coat hanger can help you clear any jams, but be careful not to puncture the duct.
2helpful
Light on for "full bag or clog." I changed bag,
Check the airflow tube behind the brush. This is a common place for clogs. The hose is more common, especially at elbows, like where it attaches to the tank. Another possibility is a dirty filter. Check this first to rule it out, then check the rest.
2answers
Bag full or clog light comes on but new bag and no blockage... Sebo x4 upright cleaner
Have you checked the filters to see if they are blocked and need cleaning/replacing. Failing that it could be the sensor at fault.
3answers
Red when bag is not full
The red light will also come on when there is a blockage in the pipes leading to the bag compartment. To test that the light is working correctly, you can unplug the flexible hose from the top of the bag compartment then switch the machine on. The red light should be off, but will come on if you block the hole with your hand. If that test shows the light is working, you need to search for a blockage - which is most likely to be in the flexible hose, but can be in the rigid plastic tube or in the base of the machine (turn it over and look in the little trap-door). Clearing a blockage from the hose can be difficult - you are more likely to be successful if you can devise a way to pull it out rather than trying to push it (as with a broom handle, for example), because pushing may just compact it. Good luck!
1helpful
Red light comes on saying bag full or clogged. Bag has only recently been changed so what do I look at next?
You look for a blockage - almost certainly in the flexible hose. Remove the hose from the machine completely (both ends, that is), then switch the machine on and the red light should not come on unless you block the hole on the top of the bag compartment with your hand. Then you need to investigate the hose, to find and remove any blockage. This is not always easy. You can try sucking a blockage out, back the way it came in, either with a second vacuum or simply by reversing it on your Sebo as best you can. This will often pull the blockage to the point where you can get hold of it with pliers or a bent wire or the like. Unless all else fails, and you get desperate, don't try pushing a blockage out with a broom handle or anything like that as you will probably only consolidate the blockage. You should also check in the little trap-door on the underside of the base to make sure all is clear there.
If you need further guidance, just post a reply here and I'll answer as soon as I can. Good luck!
1helpful
After we change the bag, it still gives us a red light
Greetings,
The bag full indicator on most vacuum cleaners is not completley fool proof. Most vacuums will just register a loss of suction, and they will then illuminate the bag full indicator, whether or not the bag is full.
If you've changed the bag, and the machine is still indicating a full bag, then this could mean one of two things.
1. Dirty Filter. According to the part diagram for your vacuum, there is a filter underneath of the vacuum cleaner bag (Bissell Part Number
203-1013) that is there to protect anything from getting into the motor. Since the filter is located before the motor, most refer to this as a pre-motor filter. Sometimes if this filter is really dirty, it can cause the vacuum to loose suction, which will also cause the bag full indicator to incorrectly display. Simply clean this filter by running it under warm water, then allow it to completely dry before replacing it in the vacuum. While the filter is out of the vacuum you can turn it back on and test to see if the light is off now that the filter is out. If the light goes off, then you have found the problem! If the bag full indicator is still on, please see the next possible problem.
2. Clog In the Vacuum. If the vacuum was run with a full bag, and when you removed the bag, the bag was completely jammed full, then your vacuum cleaner may be clogged somewhere. When the bag is packed full of dirt, the vacuum continues to try and put more and more dirt in the bag, even if it's full. Sometimes the dirt will even start accumulating inside the hose as it has no other place to go. The first place you should check is the hole that you connect the bag to. Remove the new bag that you installed and examine the hole that the bag connects to inside the vacuum. Can you see anything stuck here? If yes, do your best to try and dislodge it. If you're not able to visibly see anything here, your clog may be inside the hose, or even in the base of the vacuum.
If you have another vacuum cleaner this will really help you in clearing the clog. With the other vacuum, take the suction hose of the good vacuum, and connect it to the hose on your Bissell (still while the bag is removed, and the bag housing door is open). When you connect the hose of the other vacuum, can you hear a difference in the motor? Does the motor start running at a higher pitch when it's connected to your Bissell? If yes, then you've narrowed it down to a clog in your hose. If you can feel suction from the other vacuum through the hole that the bag connects onto, and the good vacuum's motor doesn't change noise when connected to the Bissell, then your clog is in the bottom section of the vacuum. You can sometimes stretch out the hose of the Bissell while the other vacuum is attached, and this will dislodge the clog.
If you don't have another vacuum, simply remove the hose from the Bissell completely. I believe that there maybe 2 screws that hold this hose onto the back of your Bissell, simply remove these two screws, and remove the hose. An easy way you can clear clogs is to take the hose outside, and use a water hose that has a pressurized nozzle on it, and spray down the hose while holding the hose of your Bissell vertically to allow gravity to work its magic. You can also stretch out the hose of the Bissell to get maximum benefit of gravity and the water.
If the clog is in the lower part of the vacuum, it is usually right at the suction port behind the roller brush. This is the most narrow part of the vacuums suction intake in the lower part of the vacuum, and is prone to clogs. Simply remove the four screws on the bottom of your Bissell to remove the bottom plate. Look behind the roller brush to where the suction port is to see if you can see any clogged debris.
If this doesn't help clear your clog, or fix the bag full indicator, I'd really like to try and diagnosis this further with you. Please just use the Clarification Request or add a comment and explain what happend after trying these things I mentioned above. I'll be more then happy to try and assist your further. I really hope that this was helpful to you. If you found this helpful, please be kind and rate my repair by clicking the thumbs up icon in the review.
Thank you very much,
Chris J.
13 yr Electrlux.Cuts off if hose plugs in.Says Bag Full-bag empty
This sounds like the valve assembly (full bag control) is faulty or one ov the tubes is clogged. You will have to take it to the shop.
Vacuum just stopped working.
is there a filter in it if so clean the filter.try it without the bag in it.make sure the bag is in correctly.does the bag expand when you turn it on.you might have something caught up in the hose.take the hose off and blow througfh it.if you can't its clogged.also check the inlet where the dirt goes into the bag.the inlet might be clogged.please leave feedback
Warning Light
Check the hose and wands for a clog. Usually that light means a full bag, but a clog or restriction will also cause it to come on.
Sebo automatic x1 -
Check the hose for a clog, also check the dirt inlet by the brush roll, it may have a clog also.
Top Sebo Vacuums Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
