20 Most Recent Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Questions & Answers
2answers
The vacuum stopped working while
Sometimes the vacuum will overheat, if this happens the vacuum will shut down to protect it from damage.
Unplug the vacuum, and let it sit unused 30 minutes.
Please let me know if this has solved your problem.
6/7/2020 10:57:20 AM • Electrolux... • Answered on Jun 07, 2020
5answers
Oxygen 3 will not turn on
This is often caused by a failure of a fuse on the Sumo board, or occasionally by a failure of the cord reel. I just posted a rather extensive set of instructions on how to check these things as a response to a different thread, but I will repost them here:
There is a board in the back (called the "SUMO board") which has a fuse hardwired to it. Most of the "no go" problems with this machine are related to this.
In order to check it, you'll want to take a thin flat-head screwdriver, and gently pry up the silver panel on the top of the machine. The easiest place to do this is on the side of the panel, as far toward the rear of the machine as possible.
You will then need to remove the 2 Torx screws on the rear panel, and the top body of the machine should then be able to be removed. There are two clips in the bag chamber, directly under the back portion of the bag compartment lid, which can be pressed in to facilitate removal of the back cover.
The sumo board will be sitting directly on the top of the machine, and the fuse in question will be on the right if you are looking at it from the rear of the machine. Unfortunately, if the fuse is blown, you will have to replace the entire circuit board. (Unless you feel very comfortable with soldering a new fuse onto it, which I do not recommend for safety reasons.)
You can also check continuity of the cord reel from here. On the right hand side of the board are two spade terminals leading to wires running down into the cord reel assembly. One black, one white. Checking the continuity between these terminals and the ends of the power supply cord will allow you to determine if the cord reel is providing power to the machine.
Accessing the cord reel will require you to remove the six Torx screws holding the main body to the base. Two of these are on the rear of the machine, and are very deep inside; so you will require a very long-shanked Torx driver to get at these. Two more are inside the bag chamber at the rear, and the other two are on the front handle assembly. This will allow you to lift the main body away from the base, and if you are replacing the cord reel you can pull the wires from the spade terminals and the socket on the sumo board, and feed them back down into the cord reel chamber to remove the old cord reel.
Reassembly is simply a reverse of the previous. Beware, however: getting the cord reel to align is something of a chore, so make sure that you have the retraction system functioning before you put the whole thing back together, or you'll be bummed when you finish reassembly and the cord won't retract.
(I've definitely never done that. Nope. Never.)
Hope that helps, good luck.
-R
2/13/2019 8:14:49 PM • Electrolux... • Answered on Feb 13, 2019
Electrolux L E Canister stopped working
It sounds like it may be a bad control valve assembly, which is found inside the machine. This part is controlled by the dial on the top of the vacuum and does wear out eventually. If you've got a clean bag in the vacuum, this is the most likely cause. There may be other things that could cause the problem. This is a repair that needs to be done at repair shop, I recommend one that has personnel trained in repairing the older style Electrolux vacuums like yours.
3/11/2018 6:39:58 PM • Electrolux... • Answered on Mar 11, 2018
The powerhead stop working followed by the entire
this unit is made by eureka
just carrys eletrolux name
the original electrolux is now called aerus
3/8/2018 6:51:39 PM • Electrolux... • Answered on Mar 08, 2018
2answers
I havea -1year old Oxygen Vacuum and the powerhead just quit.
the vacuum you have is made by eureka (cheap)
the original electrolux today is called aerus
3/8/2018 4:55:35 PM • Electrolux... • Answered on Mar 08, 2018
Need user manual Electrolux 1572F
Hello, this is Ava with Think Crucial. You may find the User's Manual for your Electrolux model by clicking the link below. https://www.searspartsdirect.com/partsdirect/user-manuals/EL7020A-ELECTROLUX-VACUUM-manual You can purchase a wide variety of high quality Electrolux replacement parts for your Electrolux vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/vendors?q=Electrolux I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
1/24/2018 8:08:49 PM • Electrolux... • Answered on Jan 24, 2018
2answers
I have a Z5930 vacuum and i want to trace an
This sounds like an overheating issue. The motor is most likely protected from heating, some use the airflow through it for ventilation and cooling the motor. Then there is a thermal circuit breaker.
7/12/2017 2:18:44 AM • Electrolux... • Answered on Jul 12, 2017
How do I change twin filters?
Try washing them as a n assymbley. Let tham dry for a long time and see what happens. They can be changed but not usually needed.
5/16/2016 4:31:56 AM • Electrolux... • Answered on May 16, 2016
0answers
2answers
Electrolux EL7020A Oxygen 3 dead!
-R
5/25/2015 8:40:16 PM • Electrolux... • Answered on May 25, 2015
How to replace foot pedal wihtout breaking it. Really tight trying to get pegs alligned with holes
I didn't replace it. The owner of the vacuum likes it better without the latch.
4/13/2015 11:11:19 AM • Electrolux... • Answered on Apr 13, 2015
2answers
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
3/7/2015 1:29:12 PM • Electrolux... • Answered on Mar 07, 2015
3answers
Power head turns on and off as the unit is
Probably not hose but more then likely is a problem within your wand. Try connecting your hose handle directly to your powerhead and see if you can get consisten power. I work in customer service for electrolux and more then likely it is in fact the wand
1/6/2015 6:47:14 PM • Electrolux... • Answered on Jan 06, 2015
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
221 questions posted
Top Electrolux Vacuums Experts
eVacuumStore.com
Mike Cairns
Mike Cairns
Kolbrun...
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Electrolux Vacuums
  • Electrolux Vacuums
Most Popular Question
lost screws pn5 powerhead need know
  • Vacuums
