20 Most Recent
Bissell 3522 PowerForce Bagged Upright Vacuum Questions & Answers
BISSELL CAN USE TO HARD FLOOR?
Hi Mariane. Your vacuum can be used on hard floors by setting the height setting knob to bare floors. You may want to contact your hard floor manufacturer for their suggested care instructions.
Bissell 3522 can use to wooden hard floor
Hi Marian. Thanks for asking this question. The Powerforce vacuum has a bare floor setting; however, you may want to contact the hard floor manufacturer for their recommendation regarding the use of a rotating brush.
The brush wont rotate!!!! how can i fix that???
I had the exact same thing happen to me. Take the bottom off, with only using a phillips head, and see if it melted the plastic that lets the beater bar rotate. If so, just replace the obvious parts damaged by going to Bissell.com. I just ordered my three parts for around $40.00, including shipping (three parts).
Brush stays on when upright
You are correct, the brush will continue to rotate when using the upholstery hose as stated in the user guide. The burning smell may be contributed to a couple of different reasons. Make sure the front of the vacuum is not being tipped or tilted forward when using the upholstery hose. If you continue to have difficulty, you may want to have a one of BISSELL's Authorized Service Centers inspect your vacuum.Here's a quick link to locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Floor surface selector
A part of the front wheel carriage has been moved past it's stopping point by getting it caught under some object and forcing the handle down. Can't tell without examination whether or not the carriage is damaged or not, but it's a possibility.
My Bissell power force vacum
The best thing to is to find a bissell dealer near you. most vacuums are covered under warranty and no one takes advantage of it instead they go out and spend money on something that could have been free. bissell.com would be the best resourse for that.
