Olympus FE-210 Digital Camera Logo
Posted on Feb 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My flash has stopped working for some reason - I tried to use it yesterday and all of a sudden the camera takes pictures without the flah. I went on the flash settings and made sure it was set on Auto and then tried to take the picture again but no flash still. I then set the flash to go off on every picture but still the flash did not go off I would like to know how to get the flash working again Thanks
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Feb 27, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2201057
Points
38521
Either your batteries are weak or your flash is dead.
Can't take a picture without abundant light
Does it work okay in bright sunlight without a flash? If so, try changing the options to factory default.
Canon 450D - Error 99 only when flash pops up
Flash Tube is bad inside the Flah head, tccamerarepair.com
Nikon SB600 / D90 out of sync
Check that the terminals on the flash and the camera foot are clean Use a pencil eraser to clean thyem by using a gentle rubbing motion. reconnect and test.
Please rate my help++++Thanks for using FIXYA
2helpful
2answers
Cannon EOS Rebel XS shows busy display stopped working
Just got a brand new camera. Played around with it a few nights to learn all the parts and buttons. Went to a concert tonite. While waiting for the show I took many test shots to see how the camera would work under these contiditions. Used a 75 to 300 Cannon lens. I had just got the settings about right when the show started. All of a sudden the display went dark and "busy" flashed in the view finder. But it would not take any more pictures. Taking the battery out and removing the sd card did not help. The auto focus and flash still worked but nothing else.
This camera is going back to the store if I can't get some help. PLEASE............. vj
Flash issues
It means that the battery is charging the flash! Wait a while and it should stop. Then take your photo.
Do make sure your battery is fully charged.
12helpful
3answers
Nikon Coolpix L4 flash not working
This has happened to mine a couple of times. I cannot select flash, and the blur indicator is on most of the time.
Solution is to go into 'menu', select 'SET UP' then 'reset all'. My flash selection then works again.
Since one doesn't tend to set much up with a basic camera like this, resetting shouldn't cause any issues.
Hope this helps
2helpful
4answers
Sony cyber-shot dsc-w55 flash doesnt work
hi
the flash doesnt flash anymore, you may need to replace th bulb for that. the yellow light means its a warning that the bulb is wor out.
hope this helps
Can't get the camera to Flash
EXACT same problem. Tonight I tried to take a picture and heard a loud pop sound but I didn't think it was my camera... anyway it took the picture but didn't use the flash. Later, my sister went to take a picture with the flash and it made the same loud pop noise and now the camera wont work if the flash is on.
Flash not working
If the settings was correct, force flash or autoflash, and while pressing shutter button halfway the flash indicator lit, and firing the shutter no flash(not firing). then flash assy is defective, and needs replacement. thanks
1helpful
E9101 flash error.
Hello Sayrah, there is no way you can fix it yourself. E9101 is an abnormality when flash is being charged. Contact your Sony dealer or local authorized Sony service facility. Best regards, Arpad
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
