Well thats not good, however if you can identify the Positive, usually RED, and Negative, usually BLACK. on the Fan, You can actually carefully insert the bared wire into a spare drive power connector, fans are all 12 V. You can use the YELLOW.. +12V & the alongside BLACK - 0V. This will power your fan. BE CAREFUL doing this. Once inserted use a piece of tape to secure the wires and fold them back against the Plug and secure. You may be able to buy a converter that plugs into that power connector & the fan?
I need a manual or video showing me the correct way to connect my Raidmax RX-1000AE 1000W 80 Plus Gold ATX12V power supply to my pc with 2 graphics cards , PNY geforce 9800 gt ee (no power connectors on cards but where does the pci-e cable go if anywhere? back into the psu or just dont use them ? and if my sata connections broke off can I replace the 6 pin sata cable with another brand like antec or corsair etc or does it have to be made by raidmax to be compatible
SOURCE: 920-fan command 2 pin connector from power supply not connected
then connect the fan to a 2-pin connecter if you cant do it take it to a computer place to do it for you
