20 Most Recent HP VECTRA VLI8 P3 Motherboard (KZM6120) Questions & Answers
7answers
HP MCP61PM-HM motherboard diagram
Hi RobPu,
I have searched everywhere. I even entered a chat windows with Compaq & asked for a site to download the manual for Compaq Presario SR5015LA Desktop PC which has the motherboard MCP61PM-HM in it. (Nothing). This board was made by
ECS known as EliteGroup. Still nothing. Forms for the most part do not help, only with drivers. Drivers for the board can be found on Compaq's web site.
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&cc=us&dlc=en&product=3411762
But the manual will not download. That's what is needed to hook up the front panel pins to you're case. I even looked for other possible boards who's layout was close to the MCP61PM-HM.
Nothing! I did find other Compaq PC's that also had the same board in it but after looking through the manuals, not one actuallys shows where to plug the front panel LED's on to the board. Why? Because Compaq does not support a user changing out their case for another. There is no money in that.
For the most part RobPu, system boards share some things in common. I am posting a picture for you. This pic is upside down for you so try & work with me here. Hook up you're LED's as shown. This should work for you. Pin 1 is you're starting point.
daa3370.jpg This is standard for ECS boards even if it's being sold by Compaq. Like I mentioned, for you it is posted unside down.
Try it, I'm sure it will work for you.
Enjoy!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
3/11/2023 4:44:12 AM • HP VECTRA VLI8... • Answered on Mar 11, 2023
Manuel mcp 61-hm
HP.COM GO THERE AND ASK? P3 IS RELIC NOW, zero support at all for P3 PCs, Pentium III zero/ why use any P3.?
6/9/2022 10:31:59 AM • HP VECTRA VLI8... • Answered on Jun 09, 2022
Controlador de audio para pc hp vectra kzm-6120 gratis
post in ENGLISH and be more clear what you wanted for any motherboard.what does free mean? you want free hardware for free? and why use any p3 , Pentium 3 cpu ? they are useless now.Free audio controller for pc hp vectra kzm-6120my wild guess is you meant a free, driver for the audio chip on this motherboard. mobo # decoded below to a real PC.answer is:HP VECTRA VL, P3 Motherboard as inHP Vectra VLi8 Desktop, year 1998 made . Useless now. Slot 1 Pentium 3 500mgh KZM-6120 Mobo 2x64mb PC100 6Gig HD PCI Ethernetwith windows 95 or windows 98 new.HP.com ended all support for it back in 2010 (approx)no modern OS runs here..no PCI-express slots no SATA port so modern smart HDD or SSD works here..what's to like? , it's cute but useless, sorry)
6/1/2022 12:29:53 PM • HP VECTRA VLI8... • Answered on Jun 01, 2022
0answers
3answers
How do I bypass my on board video card on my hp
The old card has to be disabled in bios or some times you can do it from safe mode by uninstall. For bios settings depending on the PC it self you would have to start the pc and first screen that shows up will tell you how to access bios settings. In the settings there is an option to turn off on board video card. Hope this helps.
3/4/2011 3:04:58 AM • HP VECTRA VLI8... • Answered on Mar 04, 2011
Usb 2.0
Your system doesn't support USB 2.0, only USB 1.1 . To have USB 2.0 you will need to add a USB 2.0 card to your system..
2/9/2011 6:08:17 AM • HP VECTRA VLI8... • Answered on Feb 09, 2011
How to install microsft word?
Use your Microsoft word installation CD/DVD.
Or you can download the free OpenOffice alternative here:
http://www.openoffice.org/
7/20/2010 12:00:22 PM • HP VECTRA VLI8... • Answered on Jul 20, 2010
MCP61PM-HM mobo won't run long enough for os to boot
I'm assuming you didn't use the Cmos jumpers to reset the cmos and only replaced the battery?
Checked board to see if there are any capacitors bulging, leaking r blowing?
You don't say why you removed it in the 1st place? I'd remove it again and test it outside the casing, see if that solves the problem, then look inside the casing to see if there is anything that could be causing a short,
Other than that, you may have damaged a component on the board when you originally removed it
2/11/2010 1:55:22 AM • HP VECTRA VLI8... • Answered on Feb 11, 2010
Corsa c z18xe engine has really bad flatspots more
hi sounds to me like either the air flow metre or the cam sensor at fault but your better of getting the car pugged into a diagnostic machine which will tel you straight away whats at fault. regards
2/1/2010 8:06:12 PM • HP VECTRA VLI8... • Answered on Feb 01, 2010
3answers
Cdboot:memory overflow error
upgrading your bios, changing rom or using another bootable disc can solve the problem
2/1/2010 10:54:42 AM • HP VECTRA VLI8... • Answered on Feb 01, 2010
Loud knocking noise for a few seconds at start up.
This is usually a sign the the hard drive is start to fail. It will just get worse until the drive completely dies. Back up your data now and plan on getting a new hard drive ASAP. If you get the new drive before the old on fails there are tools that will allow you to copy your old drive to the new drive, this way you loose nothing and are up an running in the shortest time.
1/22/2010 7:30:02 PM • HP VECTRA VLI8... • Answered on Jan 22, 2010
2answers
MCP61PM-HM spdif pin assignment? trying to
+5v Out Ground
The one all by its self is the 5 volt
the one in the middle is SPDIF Out
the one next to this is ground
1/16/2010 1:59:10 AM • HP VECTRA VLI8... • Answered on Jan 16, 2010
Driver
necesito el driver de esta placa madre
12/16/2009 8:48:51 AM • HP VECTRA VLI8... • Answered on Dec 16, 2009
2answers
Iv just formated my hp vectra vl now i have no
Go to HP's website, find the model you use, and download the sound driver. Or, if you use a third party sound card, go to their site and download their audio driver.
I hope this helps.
11/6/2009 4:32:27 AM • HP VECTRA VLI8... • Answered on Nov 06, 2009
Memory overflow error
Try Uniblue Speed Up MY Pc 2009 cracked from Loadevery.com
to optimize the ram
please please Vote 4 me
9/26/2009 4:37:22 PM • HP VECTRA VLI8... • Answered on Sep 26, 2009
Computers & Internet Logo
52 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
mcp61pm hm spdif pin assignment trying
  • Computers & Internet
