I know of this great! site, it sells all kinds of keurig products including replacement parts give it a shot http://stores.ilikenew.com/-strse-21/kuerig-coffee-maker%2Ckeurig%2C-keurig/Detail.bok
SOURCE: Keurig only brews about 2-3 oz. of coffee.
Doesn't sound like a descaler issue. I am having problems with mine and noticed that water is flowing back into the reservoir when it is pouring into the coffee cup. I think there is a valve that is not closing properly.
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
SOURCE: When brewing a cup of coffee, part of the water
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Cleaning & descaling your Keurig brewer is an important step to enjoying the best tasting coffee and keeping your brewer in good shape for years.
4 Comments
How often you need to do it depends heavily on how often you use your brewer and how "hard" your local water is ("hard" meaning how many minerals are in it). I try to do this 3-4 times a year.
Comment
Recommended For You
Open the top of your brewer and remove the K-cup holder. CAUTION: There's are two sharp needles in there. Be careful.
Comment
The cup holder is dishwasher safe. You can toss it in the dishwasher if you want. Otherwise a good rinse under warm running water is usually good. There's a sharp needle in here, so be careful.
Comment
5
Turn the cup holder over and ensure these holes at the bottom are free of any obstruction.
Comment
6
The drip-tray is removable. Give it a good clean either by hand or in the dishwasher.
Comment
7
The upper portion of the K-cup holder also has a needle. This needle has three holes in it. Insert a straightened paper clip into each hole to remove any buildup or obstructions.
1 Comment
8
Here's a close up: There's nothing you can break in here, so use some force and get that paperclip a good inch in and wiggle it around vigorously. Repeat this for the two other holes in the needle.
1 Comment
9
Use a damp, soft cloth to wipe away any coffee grinds or water stains in and around the cup holder area, and down the front of the brewer.
Comment
10
Be careful of that needle inside when wiping it down.
Comment
11
Put the K-cup holder back in the chamber. Make sure it's the right way around by aligning the arrows at the top of the holder.
Comment
12
Empty the water in the brewer's external reservoir.
2 Comments
13
Refill the reservoir with undulated white vinegar and replace on your brewer.
1 Comment
14
Run four large cup brew cycles. DO NOT use a K-cup, just run it empty . Dispose of the hot vinegar after each. This pushes the vinegar through the inside heating tank as well as all the valves inside.
2 Comments
15
Leave your brewer to stand, powered on for four hours. This allows the vinegar time to break down any build up in the tubes and valves inside the brewer.
1 Comment
16
Discard any leftover vinegar then refill the reservoir with water only.
Comment
17
Run large cup cycles until "Add Water" is displayed on your brewer's screen. This washes out all traces of vinegar from the insides of the system.
Comment
18
If you notice a vinegar-like smell or taste to the water coming out of your brewer, refill the reservoir with water a second time and run hot water cycles until empty.
3 Comments
19
Congratulations!! Your Keurig brewer is now clean and your ready to enjoy full cups of delicious coffee for months to come!
3 Comments
