Washing Machines Logo
Posted on Feb 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My brand new amana washer shakes violently when spinning
My brand new amana washer shakes violently when on the spin cycle and we have it on gentle mode. It shakes so violently that it automatically turns of and gets stuck with 7 mins left in the cycle.
Anonymous
Level 3:
  • Master 3,600 Answers
  • Posted on Feb 15, 2010
Anonymous
Master
Level 3:
Answers
3600
Questions
Helped
1576656
Points
11774
Try adjusting the feet on the bottom of the washer the floor may not be level to adjust the legs turn them with a wrench or if the lock nuts are not tight turn the legs clockwise as you look at the front of the machine till all four feet are sung on all 4 corners. This is the most common problem. hope this helps and thanks for using fix-ya
My Midea washer spins violently in spin cycle. Please help!
It sounds like there may be an issue with the balance of your washer. When a washer is out of balance, it can spin violently and cause the machine to reset. Here are a few things you can try:
  1. Make sure the washer is level: Use a spirit level to check if the washer is level. If it is not, adjust the legs until it is.
  2. Distribute the load evenly: Make sure the load inside the washer is distributed evenly. This will help to keep the washer balanced during the spin cycle.
  3. Check for foreign objects: Make sure there are no foreign objects in the drum or the drum's seal, which may cause the washer to vibrate.
  4. Check the suspension: Inspect the suspension system, which supports the drum and keeps it in balance. If the suspension is damaged or worn out, it will need to be replaced.
If the problem persists, it's best to contact the manufacturer or a professional technician for further assistance.
I have an Amana Top Load Washer Model Number ntw4800vq1 The washer shakes violently during the Spin Cylce. It will walk across the floor. I took the console off and removed the outer shell. I checked...
Hi
for the question of water comming in the spin cycle, yes its normal we call it a spray rinse. For the shaking check your leveling and also make sure that the back leveling feet when lifting back of washer up and down that the foot mechanism is functining.
Hope this helps
1helpful
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Kenmore Oasis HE shakes violently during spin cycle
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
7helpful
3answers
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
2answers
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
1helpful
2answers
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Top Washing Machines Experts
john h
