20 Most Recent
Simpson Esprit 750 Top Load 7.5kg Questions & Answers
Simpson Esprit 650 washing machine fills very slowly.
Question edited for clarity.
Question moved from Misc category to a better one
There is normally two reasons for this.
Turn off the water. Remove the hoses from the back of the machine and you will see a small metal gauze filter. They get blocked with limescale and debris from the water mains. You can clean them, descale them, or just buy new ones.
Or
The water inlet valve is not opening fully.
Water keeps running & overflows
The machine has a cut off inside that should cut supply when enough has entered so cut off or sensor fault try run it empty see if its actally overfilling as the pump should remove excess i may be blocked
Wy does it over follow
I assume you mean over flow? 2 main reasons. First check that inlet valve is shutting off. Start machine & let water flow in for a few seconds then stop the machine (lift lid or press timer in) Water flow should stop quickly. If it is slow to stop or does not stop at all then change the inlet valve for a new one. Try it several times. If all good and stops quickly then take the back panel off the machine & look inside on the right. Locate the rubber air tube from the bowl up to the panel. Inspect the tube for any worn part, any splits or holes. If found then replace the tube. It has to be air tight.
