My AEG 60820 dishwasher is continually having dirty dishes, and the soap dispenser only half empties. Have cleaned filters and ensured plates are stacked correctly but am still getting dirty dishes and soap residue on crockery
Don't know if this will help, but my dishwasher has a "propeller" device above the top and bottom racks that spins while dispensing the water. If the dishes on either rack are stacked too high (i.e. if even one plate comes in contact with that propeller, keeping it from spinning properly) the dishwasher will go through its full cycle but will not use the soap (soap door will still be closed and soap packet still intact) and will not get the dishes clean. However, it sounds like you either have a bit of a drain issue as well--or perhaps your dishwasher acts the same way as mine (if that's the case) but ceases to drain as well if blocked.
Well you can please follow the below steps - 1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open. Please post comments if you need more help or information..........
Assuming you are using the correct detergent powder, check if the dishes are remaining dirty.
The water from the impeller may not be rushing up enough due to blockage or limited movement of impeller arm. Follow the insructions to clean the impeller, filter etc or check base of drawer for obstructions to impeller arm.
If you have a water softener, you should use about half the recommended amount of soap. Never use a wet or paste detergent. As mentioned before, this unit should be under warranty.
1.) Confirm that the holes of the spray arms are not blocked with debris.
2.) Run a short cycle with an empty dishwasher and no dishwasher soap. Run the dishwasher until you hear it finish filling with water and begins the wash cycle. Add up to two cups of white vinegar to the water and allow to wash and drain. Feel free to do the same when the dishwasher fills again.
3.) Only use a brand name powder detergent (e.g. Electrosol or Cascade) in any dishwasher. Do not use a gel or tablet in any dishwasher. Do not fill the dispenser fully.
Test your dishwasher with a standard load of dirty dishes.
If problems continue, confirm that the heating element is working properly. The heating element is vital to getting clean dishes with modern dishwashers and DW detergent.
Please report back what you find.
I have the same dishwasher and kept having soap still in the dispenser at the end of the wash. Someone mentioned this, but what was happening is that the soap dispenser lid was blocked from fully opening by the top rack. You also typically have large pans in this area, so the water spray is blocked from getting under the half open lid well. I started opening the dishwasher after I heard the dispenser latch release, so the lid could fully open. After that, I had no problem with soap still in the dispenser. I started setting a timer to open and shut the dishwasher door about 20 minutes into the wash process (after the latch had released for the 2nd wash cycle), so the soap dispenser lid would be fully open. This was a pain, but it worked. The other thing to be careful of with this dishwasher is to ensure you have pushed the top rack in tight before closing the door. Look at the water connection for the top "spinner" and you will see how the plastic pipe fits up to the supply. If you don't have the rack pushed in tight, you get leakage around the connection and don't get good water spray from the top spinner arms. This can definitely affect the quality of the wash. You mentioned the dispenser lid is open when the cycle is complete, but that is because once you open the door it can fully open.
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
