MSI K9MM-V Motherboard Logo
Posted on Jan 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After cmos save display not coming? when clear
In ms-7312 amd moterboard , after cmos save display not coming? when clear cmos throug jumper then display
but if again go to cmos, then same result
Anonymous
Level 2:
New Friend:
  • Expert 133 Answers
  • Posted on Jan 05, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
133
Questions
0
Helped
30125
Points
380
If you have cleared the bios (cmos) at the jumpers....must be off the jumper for at least 1 minute! then your problem is the hard drive, either replace it or reinstall your operating system
1helpful
Changed cpu multiplier from 17 to 19 now have blank screen on foxconn a88gmx, cant reset as cannot access bios
Try clearing the CMOS --- the down side is your lose all your setting --- the up side is you should be
able to access your BIOS
Clear CMOS Jumper: CLR_CMOS1 ( Located near CMOS battery )
The motherboard uses CMOS RAM to store the basic hardware information (such as BIOS data,
date, time information, hardware password...etc.). Clear CMOS data is the fast way to go back to
factory default when the BIOS settings were mistakenly modified.
The steps to clear CMOS data are :
1. Turn off the computer, unplug the power cord from the power outlet.
2. Remove jumper cap from pins 2-3, put it onto pins 1-2 to short them.
This will clear CMOS data.
3. Return the setting to its original with pins 2-3 closed.
4. Plug in the power cord to your computer and turn it on.
5. Go to BIOS Setup to configure new system as described in next chapter.
Clear Jumper on pins 1 & 2
1 ----
2 ----
Normal
(Default)
3 ----
CLR_CMOS1
  • Disconnect the power cable before adjusting the jumper settings.
  • Do not clear the CMOS while the system is turned on.
WARNING!
Jumper Diagram Definition Description
1-2 Set Pin 1 and Pin 2 closed
2-3 Set Pin 2 and Pin 3 closed
2helpful
2answers
"Reset you're cmos/bios jumper to
HI,
No need to worry. There are many known ways to reset / remove / bypass the password:
  • By removing the CMOS battery
  • By using the motherboard jumper
  • By using MS DOS command
  • By using software
  • By using Backdoor BIOS password
Now I'll try to explain each method one by one:
A. By Removing the CMOS Battery:
Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
B. By Using the Motherboard Jumper:
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
C. By Using MS DOS Command:
This method works only if you have access to the system when its turned on because this method requires MS DOS. Open Command Prompt from Programs menu and provide following commands one bye one:
debug
o 70 2E
o 71 FF
quit
NOTE: The first character in the above commands is "O" and not the number 0.
After providing the above commands, restart your system and it should reset the CMOS Settings along with the BIOS password.
If you are curious to know how it works? then let me explain the above commands:
In this method we are using the Debug tool of MS DOS. The "O" character present at first in these commands, outputs the values to IO ports. The number 70 and 71 are port numbers which are used to access CMOS memory. By providing FF value we are telling CMOS that there is an invalid checksum and it resets the CMOS settings as well as BIOS password.
4helpful
2answers
THE Driver of MS:7312 VER:1.0 VIA Mother
go to the amd website and you can find the drivers there
3helpful
2answers
I want THE Driver of MS:7312 VER:1.0 VIA Mother
Do you mean the VIA chipset drivers or the entire Motherboard drivers? Audio, Sound, chipset, etc....
PC starts fine, but at the msi motherboard logo it
this is just a sugjestion,,i had the same problem and i cleared the bios with the jumper on the mopther board and it solved my problem..hope that helps
17helpful
3answers
Don't have vga driver
The drivers are here at MSI's site. The MS-7312 model must be an OEM name for the K9MM-V.
MS 6378 bios Was crypted. Tell me about password reset! KYBRA
You can to reset password by jumper on motherboard his name CMOS CLEAR or CMOS RESET .
it plased near the 3 volt battery .
It look like 3 pins a 1 jumper on it.
reinstall for 2 second jumper to anover two pins from 2-3 to 1-2 or (from 1-2 to 2-3 ) and password will be cleared !!!
but the over settings will be cleared too.
P.S. if you can't find this jumper just to try remove the battery for 10 minutes and disconnect power cord from power supply unit, but it may be no useful.
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
