Magic Chef 8113P193-60 gas range with Electronic Control
lock light stuck ''on'' after cleaning
Oven would not work
Unplugged range-light went off
But, Press Bake display says ''off''
Oven will still not work
Thanks
You controller is your likely culprit. There is a relay on it that controls the oven. When it first wouldn't go off, the contacts in the relay stuck together. When you unplugged it you may have had to pull it out from the wall, which may have broke the connection. It works by way of a small electromagnetic coil that brings the contacts in and out. If that coil breaks it will look like it is on, but won't have any power to the oven coils. These controllers are easy to replace, but expensive. $75 to $300 depending on what you need for your unit.
