20 Most Recent
Magic Chef CPR1100AD Gas Kitchen Range Questions & Answers
The oven pilot is set too high on a Maytag
The original poster is asking if the size of the pilot flame can be adjusted because it is so big it can audibly be heard. His oven is working perfectly as he stated having replaced both the pilot assembly and the oven thermostat. So the question remains can the size of the pilot flame be adjusted? I am having the opposite problem with the pilot flame being too small so the gas valve opens but the gas will not ignite untill the volume of natural gas fills the chamber enough to be ignited by the pilot at which point flames can be seen shooting out from under the stove. I know the pilot flame can be adjusted for the stove burners it's reasonable to believe there is an adjustment for the oven pilot as well.
Cpr1100adw magic chef
Most, if not all, gas ovens do not have pilot lights any longer. They are electronically ignited. You could have a loose wire on the igniter or a faulty igniter. If your oven is new it should be covered by the warranty.
I need to light the
Hello, Thank You for using FixYa. I will be helping you today.You can light it by removing or opening the drawer, Hold or push in on the oven knob and hold it in while you light the pilot,Keep holding it in untill the pilot wont go out.
Thank You and please rate my answer if it was helpful..
Maytags cpr1100adw model has a problem with the
Check the nozzle of the pilot. It may need cleaning. As you do this, find out if your igniter produces the spark
necessary to get your gas range working. Just send us
your e-mail so we will know the result.
Magic Chef CPR1100ADW
I just dealt with the same problem. On this model, the (already very compact) oven temperature control includes a pilot safety valve. With the control turned to OFF, push in on the knob while applying a lighted match to the pilot. After the pilot lights, keep holding the knob in for a few seconds. When you release it, the pilot flame should stay on.
Me, I'm interested in why the pilot went out in the first place and what to do if it keeps going out. IS there that repair manual (online or in print) that jvmagic was asking about?
How do I turn off the pilot light in my Magic Chef 31000paw oven? I think when it stays on it is wasting gas.
I don't know. While half a century ago it was common that pilot lights would be permanently lit to provide instant lighting of oven and hobs, because they did consume a significant amount of gas they fell out of favour and spark ignition became reliable.
Amid a number of related and unrelated accidents the gas oven began to be seen as potentially dangerous and so they were fitted with a couple of safety devices so for a considerable time the pilot light has to be relit every time the oven is used and the pilot light will be switched off when the oven burners are turned off.
Thinking back a long time, the pilots of our old cooker could be turned off using a screwdriver to turn a central service valve hidden under the hob spill tray.
