Push the battery removal button but NO battery comes out of the laptop? It is a toughbook CF-52, but used the CF-51 from the list.
The Panasonic CF52 indeed uses the same battery as
the CF51 or the CF29. Panasonic are smart and several
models share the same battery and battery part number.
To remove the battery on a CF52, you must first take off
the battery cover by pressing in and sliding the cover out
simultaneously. It is a little trick and you must press with force.
Once the cover is off, you will see either a yellow or blue
or green plastic TAB that is attached to the battery pack.
PULL on the TAB while holding the Battery Removal Button
at the same time. The battery pack should slide out.
Also please note that all modern Panasonic Toughbooks
have a Battery Calibration software factory installed
which can help to "Re-Generate" weak battery packs.
Good Luck!
Regards from Richard - Montreal Based
Panasonic Authorized Dealer since 1989.
You can always refer to manual for such kind of thing.It will bw given with diagram.
If you don't have the manual, download it from the link below
http://www2.panasonic.com/webapp/wcs/stores/servlet/TCCHomePage?langId=-1&storeId=15001
You need to register to their site inorder to downalod the manual.
