20 Most Recent Panasonic Toughbook CF-51 Notebook Questions & Answers
Hit "FN" and the "NUM Lock" key together to unlock it.
I believe thats the combination.
Let me know.
Panasonic... | Answered on Sep 24, 2018
On the Panasonic Toughbook CF-51 there is a key located on the top right next to the F12 function key called "NumLk" or Num Lock.
Press this key once and the embedded numeric keypad is enabled.
Press it a second time and it is disabled.
How do you know if it is enabled or disabled?
Simple: Observe the LED above the keyboard. If the second light with the square symbol and the number "1" is lit up, then the NumLock is enabled. If that LED is not lit up it is disabled.
Good Luck.
From Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
Panasonic... | Answered on Oct 02, 2017
This method may help;
1) Locate and remove the RTC battery
2) locate and remove the main battery and unplug power supply.
3) depress the power button for 30-60 seconds.
you do not have to solder anything to the board if there are posts ic 61,63 on MAIN PCB then just put a jumper across them while you power up. if its just 2 SMD pads just use a needle probe to arc the connection.
Panasonic... | Answered on Oct 11, 2016
ALL Drivers and Owners Manuals for
ALL Panasonic Toughbook Models are
located at the following website:
http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
Make sure to select "Manual" on the menu on the
left hand side, fourth down from the top.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Panasonic... | Answered on Feb 18, 2016
The audio or "Sound Drivers" for the Panasonic
Toughbook CF51 are located at:
Please remember to choose your operating system
and click on the "Download Now" button located at the
right hand side.
Gracias and de nada.
Good Luck. Buenas suerte
Regards,
Panasonic Canada Toughbook Dealer since 1989
On page 75 and page 76 of the Reference Manual
for the Panasonic Toughbook CF51 is described
the procedure to turn "on" the wireless lan:
1 Double-click on the taskbar.
2 Select your wireless LAN adapter and select [General].
3 Select [On] for [Switch radio].
4 Select [Networks] and select [Add].
5 Enter the profile name and network name (SSID), and then make
other necessary changes, then select [Next].
6 Make necessary changes and select [Finish].
Please note that there is no Physical Wireless Switch
on the Panasonic Toughbook CF51.
You can find the manual here and double-check yourself:
https://panasonic.ca/PCS/OperatingInstructions/CF51MK1_X_E_Reference_Manual_A.pdf
Good Luck!
Regards,
Panasonic... | Answered on Feb 16, 2016
Panasonic offers backup "Recovery Disks".
for ALL Toughbook Models
This is a service from the company itself.
There is a fee of $35.00
Please go to their website:
http://business.panasonic.com/support-computerstablets-dvdrequests
Good Luck!
Regards,
go to www.panasonic.com and then support, then look for manual download. type in the model, then it should give you the manual. if for some reason they do not have it, then just google the model number with manual after the model and you should be able to find it there. hope this helps.. Ron
remove the bios battery for 10 minutes
Panasonic... | Answered on Feb 08, 2016
You can always refer to manual for such kind of thing.It will bw given with diagram.
If you don't have the manual, download it from the link below
http://www2.panasonic.com/webapp/wcs/stores/servlet/TCCHomePage?langId=-1&storeId=15001
You need to register to their site inorder to downalod the manual.
Sue, it's not the inverter board. People who don't really know much about laptops will often diagnose them incorrectly, especially computer repair shops. The problem you're experiencing is most likely related to your motherboard. Unfortunately the most expensive part to replace on most laptops.
Your best bet is to probably just have any important files from the laptop extracted by a repair shop and then selling the computer "As-IS" on ebay. Or you could try another local repair shop to take a look at it. I wouldn't pay any money for a diagnostics since it would take most techs about 5-10 minutes to confirm what I just typed.
doesnt panasonic have a website with a support n drivers section?
make sure ur sound driver is fully uninstalled and files n folders of old driver deleted then switch off and back on and let your os system find a new device..
Panasonic... | Answered on May 19, 2015
www.howtodrivers.com/model513414.html
I wouldn't suggest buying such recovery CDs from 3rd parties when you have the option to get it from Original manufacturer. Buying it from a third party will not guarantee desired results and you may lose a lot of money. You can get it through the official Panasonic website. Here's the link:
Panasonic Mobile Computing DVD Requests
Panasonic... | Answered on Apr 01, 2015
Open the PCMCIA flap on the left hand side of the keyboard and it is on the bottom right, just below the card slot.
http://business.panasonic.co.uk/computer-product/panasonic-computer-product-solutions-service-and-downloads/panasonic-toughbook-service-and-downloads/toughbook-faqs
Panasonic... | Answered on Mar 05, 2015
I hope I am not stating the obvious by suggesting Panasonic's website.
Panasonic... | Answered on Nov 20, 2014
Load Ubuntu LiveCD and mount the windows HDD and save all personal files onto a DVD. And then reinstall windows. This will fix it. Thank you.
Panasonic... | Answered on Jun 13, 2014
Panasonic Toughbook CF-51 Notebook Logo
263 questions posted
Top Panasonic Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Toughbook Panasonic
  • Toughbook Panasonic
Most Popular Question
find restore recovery cd panasonic
  • Computers & Internet
