20 Most Recent Panasonic Toughbook 19 Rugged Notebook - CF-19K4RAX2M Questions & Answers
Go to the top right hand side to get to the search function (magnifying glass). Fill in the search box with 'msconfig'.
It should find msconfig.exe.
click on this file and you have access to the boot menu amongst other functions.
Panasonic... | Answered on Aug 09, 2014
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Panasonic... | Answered on Jan 28, 2013
On any Panasonic Toughbook you can rotate the screen as follows:
Hold down the "CTRL" and the "ALT" keys and while holding down
these two keys press the "UP Arrow" key and then release all
three keys. This will reset the screen so it is right side up instead
of upside down.
Good Luck and regards from:
Richard, Authorized Panasonic Canada Toughbook Dealer since 1989.
P.S. The arrow keys look like this: The up arrow is the one on the top
Panasonic... | Answered on Apr 06, 2018
I'm not sure if yours is the same layout as the CF-53 I use. But my F12 button has a picture of a button with light on it. I use FN-F12 to adjust the brightness of the keyboard. Mine goes through 5 brightness levels before returning to off and starting over.
Panasonic... | Answered on Dec 03, 2016
The VGA or "Video Driver" for the Panasonic
Toughbook CFY4 can be found at:
http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
Remember to choose your operating system and
then click on the "Download Now" button located
on the right side.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic... | Answered on Feb 18, 2016
From two different websites: The same answer
1) "F-11 seems to have been an emergency hot key for police use"
The website:
http://forum.notebookreview.com/threads/rubber-illuminated-kb-cf-29.239110/
2) "The red F11 can be programed to report through police dispach an officer is in trouble. This key only works with Special software used by Law Enforcement."
The website:
https://groups.google.com/forum/#!topic/toughbook/J__ssDTCm_0
Both these guys gave the same opinion and both seem
very knowledgeable.
Good Luck!
Regards,
On ALL Panasonic Toughbook Models,
if the screen stays dark I would shut-off the
Toughbook and connect an external monitor
to the VGA port (15-pin female connector),
which is usually BLUE in color.
Make sure the monitor is ON first, then
turn ON the Toughbook.
If the monitor comes on then your problem
is the backlight or possibly the inverter of the
screen.
If no image is shown on the external monitor
and the screen stays dark and you cannot
hear any startup (ie. Windows) sound, then
your video card may be defective. Very few
Toughbooks fail this way since they are
normally very very relaible but it can happen.
Good Luck
Regards,
Panasonic Canada Toughbook Authorized Dealer since 1989
yes, but you should be able to get a universal charger with proper output cheap
Panasonic... | Answered on Feb 08, 2016
Panasonic Toughbook PC Laptops usually have
very reliable battery pack. When your unit is plugged-in
but the Power is OFF, you should see an LED light as follows:
RED FLASHING: Means the battery needs replacement.
Orange/Yellow Solid: Means battery is charging.
Solid Green: Means battery is fully charged.
NO Light AT ALL: Means that Battery Pack is missing.
There is also a battery calibration utility on all Panasonic
Toughbook PC's manufactured since 2004. This is a factory
installed software and is only present in factory units.
This software may also be downloaded as a driver from the
Panasonic Toughbook website as follows:
http://pc-dl.panasonic.co.jp/dl/
Check also in the bottom right hand corner under
Windows for the battery Icon. This will indicate if
the battery is charging, present or not present,
and under Windows 7+ will indicate if the battery
needs to be replaced or not.
Good Luck!
Regards,
Panasonic Toughbook Authorized Dealer since 1989.
Have you initialised the drive?
Panasonic... | Answered on Oct 26, 2015
Follow the attached link download and install the driver and software.
Panasonic... | Answered on Mar 07, 2015
The password is what was set by the owner/administrator.
Panasonic... | Answered on May 10, 2014
Replace the screen if possible. Ifnot replace the laptop.
Panasonic... | Answered on Apr 14, 2014
Panasonic Toughbook 19 Rugged Notebook - CF-19K4RAX2M Logo
4 questions posted
Top Panasonic Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Toughbook Panasonic
  • Toughbook Panasonic
Most Popular Question
boot menu panasonic toughbook
  • Computers & Internet
