Hand Tools Logo
Posted on Dec 29, 2009
Stanley MR99 Riveter I dissasembled to release a
Stanley MR99 Riveter I disassembled to release a rivet shank I want to view a schematic to make sure I've re-assembled properly
[email protected]
  • Anonymous Feb 17, 2012
    Did anyone solve this as I have the same problem, when you take it apart the spring shots the small parts everywhere.. I managed to put it back together and its working so far, but just want to check for sure as I don't even know if some parts are missing. I contacted Stanley UK, who could not help me.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1649
Points
How do I dismantle the spiral from the outer casing of a yankee screwdriver
1helpful
Where to locate a user / service manual for Marson Air / Hydraulic Riveter tool V-3 #79050
There is a company called Blind Rivet Supply, link for manual below.
www.blindrivetsupply.com/V3.html
2helpful
Riveter doesn't eject the pin after rivet is seated.
If your pop riveter is the same as mine, after you install a rivet you must turn the tool over and spread the arms and the stem from the old rivet will drop out. I had one stem stick inside the tool, and had to disassemble the whole thing...if you have to do this, have a friend with you...you need 4 hands.
How to take off window regulator 1993 fordcrown vic
remove trim panel and check for bolts holding the regulator in. Some cars have rivets, big ones that have to be drilled out and a heavy duty riveter to install. Call your local dealer and ask them how much to rpelace and if it has rivets.
3helpful
How to replace window regulator
you will need to drill out some rivets. Replace with ntus and bolts and washers & lock washers. Make sure they don't hit glass going up and down. Otherwise you will need a heavy duty riveter.
please rate as fixya if this helps.
Motor —Front Door
Special Tool(s) swj~us~en~file=st1132a.gif~gen~ref.gif Heavy Duty Riveter
501-D011 (D80L-23200-A) or equivalent
Removal
NOTE: The window regulator and motor are removed as an assembly.
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
  1. Remove the front door radio speaker.
  1. Remove the latch remote control. For additional information, refer to Section 501-14A .
  1. Remove the front door watershield.
  1. swj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Support the window glass to avoid damage.
    Raise and support the front door window glass to the full up position.
  1. Disconnect the power window motor electrical connector.
  1. Remove the window glass to regulator nuts.
  1. Remove the motor and window regulator assembly.
    1. Drill out the rivets.
  1. NOTE: Prior to motor removal, make sure the regulator arms are in a fixed position to prevent counterbalance spring unwind.
    Remove the power window motor.
    1. Remove the bolts.
    1. Remove the power window motor.
2004 Mercury Monterey left frnt window sector gear R&R proceedure
are you a techie? You need a heavy duty riveter to do this repair. May have to rent or borrow from auto store.
here's the procedure
Front Door Trim Panel s4w~us~en~file=adobe.gif~gen~ref.gif Printable View (251 KB) NOTE: LH side is shown. RH side is similar.
  1. Remove the parts in the order indicated in the following illustration and table.
  2. Item Part Number Description 1 23942/23943 Mirror access panel 2 1722897 Cup assembly 3 W56904-S424 Window regulator control switch panel screws 4 14A665 Window regulator control switch panel
    Removal Note 5 W701930-S424 Front door trim panel screw 6 W701930-S424 Front door trim panel screw 7 N602703-S61 Front door trim panel screw 8 1723943 Front door trim panel 9 W705590-S300 Nut insert(s)
  1. To install, reverse the removal procedure.
Item 4: Window Regulator Control Switch Panel Removal Note
  1. If equipped, disconnect the electrical connector(s).
Door Window Glass — Front s4w~us~en~file=adobe.gif~gen~ref.gif Printable View (328 KB)
Special Tool(s) s4w~us~en~file=st1132a.gif~gen~ref.gif Heavy Duty Riveter
  1. Remove the front door trim panel. For additional information, refer to Section 501-01 .
  1. Position the watershield aside.
    To remove individual parts, only carry out the listed steps: Part Steps Front door window glass 1, 3 Front door window regulator 1-5 Front door glass run 1, 3, 6-8
Item Part Number Description 1 W706495-5100 Rivet (2 required)
Removal Note
Installation Note 2 N8621986 Nut (3 required) 3 21410 Front door window glass 4 W706495-5100 Rivet (4 required)
Removal Note
Installation Note 5 23200 Front door window regulator
Removal Note 6 N800507-S Bolt (2 required) 7 21596 Front door glass run 8 — Front door glass run (Part of 21596)
Item 1: Rivet Removal Note
  1. Connect the window control switch.
  1. Connect the battery.
  1. Position the door window glass halfway down to gain access to the door window glass rivets.
    • Remove the rivets.
9391398.gif Item 4: Rivet Removal Removal Note
  1. Remove the rivets.
Item 5: Front Door Window Regulator Removal Note
  1. Disconnect the electrical connector.
  1. s4w~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Prior to power window motor removal, make sure the regulator arms are in a fixed position to prevent counterbalance spring unwind. Failure to place the regulator arms in a fixed position can cause the spring to suddenly release resulting in personal injury.
    NOTE: The counterbalance spring assists the window in the upward direction.
    Remove the bolts and the window regulator motor.
Item 4: Rivet Installation Note
  1. Using the special tool, install the rivets.
The head will not pull back on the rivet shank at all
Hi
Disassembly and clean it.
best regards savumihai71
1helpful
2answers
Left front window will not come back up, motor just makes a whirring noise
I have had this problem several times before(every door). The regulator is cable operated and can come off the nylon pulleys. I have been able to get them back, but usually the nylon is damaged and it won't stay on. The other thing is the regulator is riveted to the door shell with 1/4" rivets. You will need a riveter capable of setting them. The best way to remove the rivets is to use a hammer and punch to first drive out the steel mandrel before drilling with 1/4" drill. The regulator itself is around $50 from Ford, you'll want to get the correct rivets at the same time. The rivets that hold the glass to the regulator are different than the ones that hold the regulator to the door(longer). You can get an inexpensive riveter at Harbor Freight for less than $20.
Top Stanley Hand Tools Experts
john h
Larry Ng
Larry Ng
Ziyaad Khan
Ziyaad Khan
Level 1 Expert
Are you a Stanley Hand Tool Expert? Answer questions, earn points and help others
