Magic Chef 9122 Gas Single Oven Logo
Posted on Dec 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have Chef oven (gas) and need to know how to ignite it? Previous residence closed the main gas valve and now I reopen it, but oven still looks need to reignite or restart? how do I?
Anonymous
Level 2:
  • Expert 71 Answers
  • Posted on Dec 23, 2009
Anonymous
Expert
Level 2:
Answers
71
Questions
0
Helped
33304
Points
220
You should find a reset botton in the back of the oven, close to the bypass for the valve, it should be instructions next to it.
2helpful
Magic chef oven with uniburners oven will not light. igniter gets red hot but seems like no gas coming at all. burners on top work fine.
Since the bake burner does glow yet no flame that means that the igniter is weak and should replaced...the way the igniter works is that it comes on and get very hot where upon getting hot it draws a certain amount of amperage which will allow the gas valve to open resulting in a flame. The igniter is indeed coming on yet its not getting hot enough to draw the proper amp drqaw to open the gas valve...by replacing it with a new fresh igniter it will draw the correct amprage and let the gas flow.
GENE
The oven of my Chef 635 model GSC6635SLP doesn't ignite (no gas comes out in oven, yes from plates), the ignition element is working, there is electricity in terminals connected to thermo valve but it...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 13, 2011 • Ovens
Oven will not light. the glow element comes on but the burners will not ignite to heat the oven
You could have a weak glo bar, that is common or the main oven gas valve could be bad.You have to trouble shoot and find out which it is.If you happen to have a seperate broiler in that range that has a separate glo bar you can use it in the lower oven to see if it will open the gas valve.Hope this helps.
Replaced bad thermostat on Magic Chef model 9112xpb. Ignitor now glows orange but oven still won't start. Does gas valve on bottom of oven need to point up or sideways to start?
Gas shut off valve handles are perpendicular to the gasline when closed and parallel when opened. If you are referring to the appliance regulator behind the stove, the lever should face up or out, as opposed to sideways. This particular lever only shuts gas down to the oven and not the stovetop.
Let us know if you need more assistance.
1helpful
I just cleaned by hand by magic chef wall oven and now I can't
Pilotless ignition means that a hot surface ignitor lights the oven burner. It does take a little bit of time to light the burner. Maybe 30 seconds. If you want to make sure it lights take the bottom panel out from the oven and observe the hot surface glow and the burners light. No real danger as the gas valve will only open after the hot surface ignitor has satisfied the gas valve. Let me know how it goes. ken
7helpful
THE OVEN WILL NOT HEAT
How old is the unit? Sometimes the igniter can glow but if it isn't drawing the right amount of power to open the gas valve then that is the safety that is built into the oven... So unless the power requirement is meant gas valve will not light. Even though the hot surface igniter is glowing red hot. chances are the igniter is bad. Let me know what turns up. ken
Old Magic Chef Gas Oven won't light
sounding like thermostat isn't working. If you could ohm out the t-stat should be closed when you call for heat. If that passes the test then only thing it could be is the gas valve.
2answers
Magic chefa313-230lw gas ignitio
hi .thanks for the question . A very common problem with gas ovens replace the igniter thanks the appliance doc
1helpful
2answers
New gas valve, new gas smell
CG, unfortunately you replaced the wrong part. The problem with your oven is the igniter. The igniter is wired in series with a safety valve. The safety valve monitors the amount of electrical current flowing through the igniter when you ask it to "bake".  When the igniter gets "weak" it won't allow current to flow through it properly, this will keep the oven from heating. It will also cause your symptoms as well...
Here's the scenario; Say your safety valve is "looking" for 2.5 amps of electricity flowing through it before it'll open up and allow gas to the manifold. Your igniter is designed to allow 2.8-3.2 amps to flow in good operating condition, but your igniter has become "weak"... it's now allowing 2.48-2.51 amps. The safety valve is sensing this and opening and closing rapidly, allowing gas to flow through it (fluttering). BUT! the igniter is not hot enough to ignite the gas and/or there is not enough gas to ignite do to the fluttering effect of the valve. Sometimes it'll light sometimes it won't.
Your igniter is the cause and needs to be replaced.
Before you begin the repair, you should have the new part on hand. The part number is WB2X9154 and can be purchased at your local appliance parts retailer for about $50.00. Here's one online for $65.00.
First, UNPLUG YOUR OVEN!
To replace it... Remove the racks and lower panel (oven floor). This will expose the burner manifold where the igniter is mounted.  (It's the round thing on the manifold near the back... it has 2 wires going into it.) You'll need a 1/4" socket or nut driver to remove it.
(*TIP---> before removing the screws from the igniter, put a few drops of liquid dish soap on the threads to lubricate them. If you do this, you will not strip the threads of the screws and it will ease their removal.)
The new igniter kit will have two ceramic wire nuts in it. Cut the two wires off of the old igniter and strip them back about 3/8". Then connect the wires of your new one to the wires in the oven using the ceramic wire nuts provided. Then mount the new igniter and rebuild the oven.
(*TIP---> The new igniter is very fragile! [that's why it came wrapped tightly in bubble wrap] Handle it gently!)
There ya go! Total job time? ~45 minutes.
Top Magic Chef Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
