20 Most Recent Magic Chef 9512 Electric Single Oven Questions & Answers
If it has a timer, make sure it is set to manual,and not flashing auto.
In the auto mode the oven will not work.
Plz rate this solutioin.
Thanks.
Magic Chef 9512... | Answered on Sep 06, 2013
F1 Error Code - Defective touch pad or clock (ERC)
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
Magic Chef 9512... | Answered on Jun 26, 2012
if the door is unlocked then clean all the grease and let go, if the oven is still locked then get a tech down to your house to have it unlocked since its not safe to have it run again with greaase
Magic Chef 9512... | Answered on Sep 05, 2011
What you want to check or have checked is if the wiring on the new igniter was accidently not properly insulated and some or the wiring is bare and touching metel shorting the breaker each time the oven is turned on.
Magic Chef 9512... | Answered on Aug 16, 2011
Welcome to Fixya.
The problem could be:
1. Watchdog on board or
2. Touch membrane defective
To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board .
Thank you for using Fixya!
Magic Chef 9512... | Answered on Nov 21, 2010
try to reset it ..by unplugging the oven ..and put it back after 30 minutes or so ...it may be a function set ..and remained there ...if the fan is not stopping ..than it is probably a wire that has a bad connection and feed s it with electricity when it not supposed to...probably the isolation went off from the heat ...and in this case you need to call for a specialized hand to see the short and fix it ..
Magic Chef 9512... | Answered on Aug 31, 2010
I have the same problem with the beeping and screen flashing F1 does anyone have a solution yet?!
Magic Chef 9512... | Answered on Jun 27, 2010
this is usually a temp sensor probe problem.check you wiring between the probe and the electronic control board. at room tempt check the resistance on the probe if it less than 500 ohms replace the probe.
Magic Chef 9512... | Answered on Feb 23, 2010
Magic Chef 9512 Electric Single Oven Logo
48 questions posted
Top Magic Chef Ovens Experts
Thomas F. Schneider
MARLON KELLER
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
View Most Popular
Magic Chef Ovens
  • Magic Chef Ovens
Most Popular Question
getting continues
  • Ovens
