20 Most Recent GE JGRP17 Gas Single Oven Questions & Answers
There is a lot of troubleshooting and repair advice at the link I'm providing. In addition, they have parts available and hot-to videos. I'm sure you'll find your answers there.
GE Oven Not Heating
GE JGRP17 Gas... | Answered on Jan 03, 2018
go to this web site put in your model number and you can download the whole use and care manual http://www.geappliances.com/ just look for the search box half way down on left select use and care then put in the model number
GE JGRP17 Gas... | Answered on Jan 19, 2015
Check to see if there is something blocking the burner tube. It sounds like it is blocked.
GE JGRP17 Gas... | Answered on May 10, 2014
According to the model number you supplied it looks like your oven use a glow bar ignitor not a pilot light. In that case there is no place to hold a fire. what happens with these when you turn the oven on 120 volts goes to the ignitor causing it to heat up ,the amp draw across the ignitor causes the gas safety valve to open, and then lights the gas. So if you turn your oven on you should see a bright red glow if not probably the the ignitor, to check it you would have to verify you actually have power going to it. If the ignitor glows but the gas valve does not open you will still need to replace the ignitor has to pull about 3.2 amps across ignitor to open safety valve. Your broil burner works the same way. And most of the ovens the floor of the oven comes out to allow easier acess to the ignitor. also if you have to change the ignitor put just a dab of dish detergent on the screws to help from stripping them
GE JGRP17 Gas... | Answered on Feb 14, 2014
There is a cover plate that has two screws holding it down. Inspect the pilot area and you will see a hot surface igniter sitting right next to it.. That is what lights pilot and then the pilot lights main burner. You need a new igniter. Also do not touch any part of the hot surface igniter as human oil will shorten the life of part.
GE JGRP17 Gas... | Answered on Dec 24, 2013
igniter needs changing
very easy to do , I changed 3 last week on my rentals
wont take but 15 min
GE JGRP17 Gas... | Answered on Nov 20, 2013
no this should not have kille your bird.sorry to here about your bird. when using a self cleaning oven you should not use any king of oven cleaner in this will give of a smell that could have possibly cause the death of your bird but if no cleaner was used then your oven is in the clear
GE JGRP17 Gas... | Answered on Oct 21, 2013
Does the fan sound like a squeling or rumbling?Is the fan blade itself scraping on something?
GE JGRP17 Gas... | Answered on Sep 15, 2013
Hello Robin,
THis is usually a problem with the oven control, but sometimes is caused by the keypad. Here is a more detailed description of the problem:
http://www.fixyourboard.com/techzone/ovens/f1_error/f1_error.html
Best Regards,
Bruce
GE JGRP17 Gas... | Answered on Mar 20, 2013
GE JGRP17 Gas Single Oven Logo
180 questions posted
Top GE Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Ovens
  • GE Ovens
Most Popular Question
oven will heat prescribed temperature
  • Ovens
