Yes. In most cases you can reset your D-link DP-300 series or DP-301 series print server yourself even if you don't know the password or IP. This comes in handy in situations such as when the server has made up its own password after being connected to a new router.
Cross your fingers and try the following steps...
1) Install the psadmin software if you have not already. If you have lost the psadmin software then search for it on the web.
2) Start the psadmin software and click "factory reset".
3) If the software demands a password, try "SYSxxxx", where xxxx stands for the last four digits of the MAC address located on the underside of your server. (Example: if your MAC address were "63 XE 29 44 F2 96", then your password would be SYSF296.)
4) Click yes to confirm the reset.
5) Follow the non-intuitive instructions provided with your server to set it up again. (Note that a Quick Install Guide will likely be more useful than a manual for this step. If you have lost your Quick Install Guide then try downloading it from D-link's website, http:/www.dlink.com/default.aspx Locate your model via "product quick find" or "find your product" then click on "support resources" and look for a quick installation guide.)
Shahzad IT Department
Mitsubishi Motors KSA
