20 Most Recent
D-Link DP 303 (DP-303) Print Server Questions & Answers
Hi - in my three-computer, PC network environment,
Shut down all the printers and computers.
Boot all the printers first to establishe their IP addresses.
Then turn on a computer and search the network group for what is online. All the printers should show as long as they have theit IP address.
Once their static IP is established the rest shall follow with what ever IP addresses are left. A dynamic IP setup grabs the available ip address and can conflict with a device that has that static IP if the static IP device is powered up after.
Where did my printserver go !!! ???
From your initial troubleshooting steps, it sounds like you are having an IP connectivity issue. I will make the assumption that your print server is configured with DHCP and not a static IP address (If it is has a static IP address, make sure it is configured for the correct subnet). If this is the case, you should be able to log on to your broad band router and see what IP address was given out for it in the DHCP Lease section.
Next, try pinging (open a command prompt and type: ping 192.168.2.103) the IP address of the print server. This will confirm that you have proper connectivity to it. Next, make sure you have file and print sharing enabled on your Win XP machine.
DP-303
Perhaps the XP firewall software is preventing PS Admin from connecting to the print server?
We forgot the password
try this and see if it works for you please email me and let me know
first
To reset the print server using PS admin follow the steps given below:
Step 1 Open the PS Admin software, select the print server you wish to reset to factory defaults, and then click Factory Reset.
Step 2 Click Yes.
Step 3 Once the reset procedure has been completed, Click OK. The device is now set to factory default settings.
For D-Link's preferred Home Networking application please try http://www.networkmagic.com/nmlp/dlinksupport.php from Pure Networks. It simplifies Microsoft Networking and may allow you to trouble shoot your network on your own.
like i sai dtry this and let me know thanks keith
Can't print
try unplugging the printer and router and restart them your ip- my be used by other device.
quicway.com
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
