20 Most Recent D-Link DP 300U (DP-300U) Print Server Questions & Answers
Click on start>run>cmd. Then type in ipconfig /all. That will give you the IP address to your gateway and any other address you need.
Please rate this solution.
D-Link DP 300U... | Answered on Mar 04, 2017
192.168.2.1
Try this ;)
D-Link DP 300U... | Answered on Nov 28, 2014
Your type of d-link the highest version is 1.20 which can be downloaded from ftp://ftp.dlink.com/Printserver/dp300U/Firmware/dp300u_firmware_120.bin and updated on your d-link administrator page.
D-Link DP 300U... | Answered on Jan 26, 2012
ok have you tried changing the settings in the print server usually a printer must be configured on the print server before it can be used if it is on the network try telneting in to it through a web browser like you may a modem
D-Link DP 300U... | Answered on Oct 13, 2011
If the default password has been changed then -
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
D-Link DP 300U... | Answered on Apr 16, 2011
Can anyone tell me, what IP Address when reset to default? thx's...
D-Link DP 300U... | Answered on Jan 25, 2011
u need to replace the power adapter
D-Link DP 300U... | Answered on Jun 17, 2010
If your printer has a network port you should be using the network adapter.
Otherwise you want to make sure you connect the printer with a USB cable to the appropriate port on the D-Link.
Once the USB cable is connected you should be able to add the printer from your computer as a shared printer.
You will not normally see any activity lights on your router for the USB connection because it does not send or receive information the same way the LAN cables will.
I do recommend a LAN cable though as it works much better with routers. If your printer does not have one I would look into getting a network printer.
Thanks,
Pat
D-Link DP 300U... | Answered on May 12, 2010
Reset button is in back panel of printer sertver.
Press it for 10 seconds.
Then all settings goes to defaults.
Reset button is small round in back side of router you can press it's pin with any ball -pen.
Let me know if you need further assistance.Thanks.
D-Link DP 300U... | Answered on Jan 04, 2010
DP 300U's can get be pretty uncooperative when attached to a different router. One solution is to reset the DP 300U to its factory settings. Use the PS Admin software to do this. (If you lost the PS Admin software, you should be able to download it from the internet.) If the software prompts you for a password and you do not know it, try "SYSXXXX", where XXXX is the last four digits of the MAC address located on the underside of the print server.
After you reset the DP 300U you will need to set it up from scratch, a process which is not particularly intuitive. Refer to your "Quick Install Guide" (download it from D-link's web site if you don't have it anymore).
D-Link DP 300U... | Answered on Dec 31, 2009
Try using the PSAdmin software to do a factory reset (download it from the internet if you need to). If it demands a password try the following:
password: SYSXXXX (Where XXXX is the last four digits of the MAC address, which can seen on the underside of the server)
I learned about the password part from http://www.fixya.com/support/t224263-dp301p_psadmin_password_forgoten, which has additional helpful details.
how reset password for dlink 300 print server please give me solution
This sounds like a defective driver problem with the print server. reinstall the driver. If this does not solve the problem then contact D-Link support for further advice.
D-Link DP 300U... | Answered on Sep 24, 2009
D-Link DP 300U (DP-300U) Print Server Logo
39 questions posted
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
DP D-Link
  • DP D-Link
Most Popular Question
reset problem
  • Computers & Internet
