Sony VAIO VGN-CR240E/B Notebook Logo
Posted on Dec 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW TO GO TO BIOS IN VAIO VGN-FZ4000 - Sony VAIO VGN-CR240E/B Notebook
Florin
Level 3:
  • Master 733 Answers
  • Posted on Dec 15, 2009
Florin
Master
Level 3:
Answers
733
Questions
0
Helped
166567
Points
1640
You can go in bios with F2 this is valid for all or if you cant press Del. but be advised that if you do not know what to do you may unset something that you need.
1 Related Answer
kinkate18138
Nishanth Kesavan
  • 117 Answers
  • Posted on Dec 16, 2010
SOURCE: My Sony Vaio FZ4000 does
Unfortunately, if a VAIO is not turning up after a failed BIOS update, the only option is to flash the original BIOS. This is only done at Sony service center.
You need to contact a Sony service center near your area. it get the BIOS flashed.
Thanks!!!!
3helpful
HAVE TRIED CHANGE THE CMOS BATTEWHAT CAN I DO NXTRY TO REMOVE BIOS PASSWORD BUT IT COUDNT WORK,?
Sony Vaio PCG and some Vaio VGN Series use the last 7 digits of the laptop serial number to calculate the bios master password. The serial number for a Sony Vaio is often located on the bottom of the laptop on a white sticker. The serial number may also be found by removing the battery and checking in the battery compartment. The link to unlockbiosrecovery.com below works on the following models:
PCG-C, PCG-F, PCG-GR, PCG-GRS, PCG-GRT, PCG-GRV, PCG-GRX, PCG-GRZ, PCG-N, PCG-NV205, PCG-QR, PCG-R, PCG-SR, PCG-SRX, PCG-TR, PCG-V, PCG-VX, PCG-X, PCG-Z, VGN-B, VGN-FS, VGN-S, VGN-T, VGN-TX1, VGN-X
I use http://www.unlockbiosrecovery.com/Unlock_Sony_Bios.php
For $20 they use the last 7 digits of the laptop serial number to calculate the bios master password and then email it to you in an hour. They guarantee it to work and you can call them if you have a question.
I have a sony Vaio VGN_FZ4000, after upgrading to Windows7, it says there is no camara instaled, I went to sony help but all they have are software for the camara no drivers. the camera my laptop have is...
Those 2 software packages offered by Sony on their web site, (a) ArcSoft Magic-i Visual Effects, and
(b) WebCam Companion Software, may just include the driver necessary to get their packages to
work with Win7 - pick one an install it - if the camera works, you got the driver. If the camera still
refuses to work, then all you have to do is de-install the package, install the other one and
give that a try.
The Sony drivers support page (for the Vaio VGN-FZ4000):
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGN-FZ4000®ion_id=1
1helpful
Need SONY VAIO VGN-FJ170B BIOS password reset method...Please help.
To reset the BIOS password on your Sony VAIO laptop read the information from this link.
I cant remember the bios password of my notebook model sony vaio vgn-a497xp
You can reset the BIOS password. To reset the BIOS password read the information from this link.
My Sony Vaio FZ4000 does not turn on after a bad bios update
Thanks!!!!
I have sony vgn fz4000.it gets heated very soon after starting. Is there any solution
Press ctrl alt del butons together. Go to Task Manager and check if any Process is running at 100% or close to that CPU speed. This usually happens if a program or service has failed and the CPU is trying to complete the job. The CPU heating problem should be cured once you have found the program using your full CPU power. Try to uninstall that program completely. If you need it then try reinstalling again after a reboot. Read more at www.fixpcfreeze.com
Can I upgrade Vaio laptop bios in Dos?
BIOS upgrades are USUALLY done in DOS. Most times, you need to boot from a floppy or CD that is specific for BIOS upgrade. Some BIOS upgrade software may be apllied through Windows, but this depends on your computer manufacturer.
BTW, if your computer is running ok, DO NOT MESS UP WITH THE BIOS. You may risk ruining your laptop.
IF IT IS NO BROKEN, DO NOT TRY TO FIX IT.
2helpful
Install wrong bios on sony vaio laptop model vgn cr 353 so dont see anything in bios setup or some garbeg seen in bios cant acess bios
BIOS is gone...u need to change the BIOS IC or may be the full Motherboard...
the other option is to go to tech shop and "TRY" have ur BIOS flashed with the correct BIOS software...
1helpful
Sony vaio VGN-S56GP pawer on Bios password
Hello, I can unlock ANY  SONY VAIO bios password (PCG AND VGN MODELS). If anyone have questions feel free to visit www.laptoprebirth.com or send an emailto [email protected] WE SUPPOR OTHER BRANDS LIKE ACER HP COMPAQ TOSHIBA ASUS GATEWAY DELL FUJITSU SIEMENS SAMSUNG
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
