20 Most Recent
Sony VAIO VGN-CR240E/B Notebook Questions & Answers
Dear sir, i owe a
Hi.
You may download all the Drivers and Applications for the Windows 7 64-bit Operating System from the below link:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR240E&SelectOS=6
Please select the Operating System as "Windows 7 64-bit Operating System" and then download the required Drivers or Applications.
Once you have installed the Drivers and Applications, please restart the Computer for the settings to take effect.
Hope this helps.
Please feel free to contact for further assistance.
Thank you.
Suresh
Sony VAIO...
Answered
on Aug 09, 2011
After upgradin to windows 7 the SD card slot
You can go to Sony's Support
site to make sure you have to download the most recent driver for the card reader. However, sometimes new drivers aren't being created for Windows 7 for older hardware. One the support site select your OS and see what comes up. There are also sometimes drivers released for 32bit, but not 64 where workarounds need to be implemented in order to get them to work, like installing a 32bit driver in compatibility mode.
Hope this helps
Ray
Sony VAIO...
Answered
on Mar 02, 2011
I have been connecting my Sony Vaio VGN-FE21M for
I need to know what operating system you're using (like windows vista). However, it seems like the control has moved to the LG screen, and not laptop. You can set several options when connecting a monitor to a laptop - both screens are available, one screen is off and the other screen is off.
Please post your operating system so that I guide you how to change these settings.
Sony VAIO...
Answered
on Nov 23, 2010
I have sony vaio vgn-fz31sr.It
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Sony VAIO...
Answered
on Sep 27, 2010
It feels like my arms
Since that is a very dangerous situation on your part, I believe it must be attended seriously by Sony. As I read their terms and conditions, if the customer has encountered, fire, shock, spill or any emergency situation, then you have to call Sony immediately becuase they considered it an emergency situation. This causes by faulty wiring on the part of the laptop. Call Sony immediately...
Sony VAIO...
Answered
on Aug 31, 2010
I have sony vgn fz4000.it gets heated very soon
Press ctrl alt del butons together. Go to Task Manager and check if any Process is running at 100% or close to that CPU speed. This usually happens if a program or service has failed and the CPU is trying to complete the job. The CPU heating problem should be cured once you have found the program using your full CPU power. Try to uninstall that program completely. If you need it then try reinstalling again after a reboot. Read more at
www.fixpcfreeze.com
Sony VAIO...
Answered
on May 06, 2010
Code error 0xc0000185
Follow these steps
First you should Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
- Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site of your laptop
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing blue screen
Sony VAIO...
Answered
on Feb 19, 2019
