SOURCE: 935 service printhead error
Hello. Unfortunately, if that's the case, there's not much you can do about it but have it serviced. Hope I can assist you more with it.
SOURCE: Lexmark E350d erreur 935
Yuot should let the printer toruned off at least 1- 2 hors, and then it will work again. It is a heating problem when you print a lot of pages.
Make sure the printer is plugged straight into the wall and not through a surge device or power strip. Please try this even if the printer previously worked correctly with this surge device. Power strips and uninterrupted power supplies can cause a low amperage problem, which can trigger a false printhead error.
You may also want to try plugging the printer into a different wall outlet to see if the printhead error continues. This will eliminate the power source as a possible cause of the issue.
If still have the same issue a replacement of your printhead assembly is necessary.
For further assistance please contact Lexmark Technical Support.
Please click on the link http://bit.ly/q5DVho to see instructions on how to go about the procedure.
For additional assistance, please contact Lexmark Technical Support
