When the TV is turned onto any HD channels part of the picture is cut off at the top of the screen and at the bottom. So when I am watching sports the score is completely cut off or I can only see half of it. The TV is only two years old, what can I do?
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
How are you getting HD picture to the TV..?
Ensure that if sky HD for example, the SKY HD output settings are set to 16:9 aspect ratio.
Also check the Auto format option and others inside the sceren menu menu are set and that the 4:3 option is set to default.
Attempt to use the screen aspect ratio button on TV remote also (box with arros pointing out of top,bottom and both side)., however, i belive whilst in HDMI input this button doesn't function.
Have you checked the screen aspect ratio, or tried settings menu
I had the same problem not seeing the whole picture and I clicked on HD Zoom and it worked. I have Comcast cable. THANK YOU!
