20 Most Recent
Samsung LE26R73BDX 26 in. HD-Ready LCD Television Questions & Answers
Hi, my Samsung LE26r73bdx has developed three grey
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations
. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
10/19/2017 5:56:40 AM •
Samsung...
Answered
on Oct 19, 2017
Sound has gone on Samsung LE23R87!
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
4/11/2017 2:52:37 AM •
Samsung...
Answered
on Apr 11, 2017
Displaying no signal
check the video cables inputs on the back of the tv. they might be plugged into the outputs instead of the inputs....try switching from av1 to av2...
11/22/2012 4:17:47 PM •
Samsung...
Answered
on Nov 22, 2012
SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
8/6/2012 3:12:17 PM •
Samsung...
Answered
on Aug 06, 2012
Remote control does not work
Your remote control need cleaning. Check this site 'Electro-help" where you can find details about how to repair or clean a remote control. Google for it.
5/3/2012 2:18:15 AM •
Samsung...
Answered
on May 03, 2012
Samsung LE26R7 LCD TV
I get
Hi,assuming you have the volume up on your receiver, and on your TV, the
problem must be in either: The A/V sockets on your TV = try another
set of sockets (eg: AV1, AV2, AV3,etc)
The scart-to-AV lead supplied with the receiver = take it back to your supplier.
The receiver itself = take it back to your supplier.
Note,
though, that some new TVs have so many A/V, Component, S-Video sockets
on the back that it is hard sometimes to work out which audio sockets go
with which video socket, so you may have (for instance) the yellow
video plug in AV1 while the red & white audio plugs are in AV2.
Hope you're able to sort it out.
Also, check the 'mute button' if your using those cheap black scart leads,
please get rid and buy better ones as they are only to get you started
and wear out quickly hence your problem..
You can do the old Sky trick of pulling the power cord out for 30 seconds and that did the trick.
6/13/2011 1:23:04 PM •
Samsung...
Answered
on Jun 13, 2011
Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote
select the Reset option. Using the right arrow button at this point
will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
5/19/2011 4:43:16 PM •
Samsung...
Answered
on May 19, 2011
There is a permanent broad coloured stripe down
LCD display may have moisture on tinoxide which can be burned off in low humidity room. LCD tft may be leaky, which can be burned in by standby for a few weeks. Video output semiconductor IC may be needed burn in for a week. Most of these problems are due to moisture in the air, and lack of use of the TV. Have power on 24/7 may solve the moisture problem.
10/1/2010 9:43:29 AM •
Samsung...
Answered
on Oct 01, 2010
Got no picture only sound
You most likely have a backlight issue with this TV set. Could be the
inverter circuits for the backlights. The inverter is the power supply
source for the backlights. there could also be a screen driver
problem. This would entail changing the entire board. You should call
in an authorized LG repair center to check this set out for you. Good
Luck and please let me know what you found out about this TV set.
6/3/2010 2:01:19 PM •
Samsung...
Answered
on Jun 03, 2010
